XI generates only portion of the Graph view
dlukinski
Post by dlukinski »
Hi
since 5.5.5 upgrade our XI generates only the portion of the JPG or PNG Graph view (as attached)
Please help with this
Thank you
benjaminsmith
Re: XI generates only portion of the Graph view
Post by benjaminsmith »
HI @dlukinski,
Would you be able to try an upgrade to 5.5.7? We've updated libraries that generate reports and graphs, and that maybe the issue here. Also, 5.5.7 contains security updates and performance improvements.
Before upgrading, please make a backup or take in snapshot if you are using a VM.
Nagios XI Upgrade Instructions
https://assets.nagios.com/downloads/nag ... ctions.pdf
dlukinski
Post by dlukinski »
benjaminsmith wrote:HI @dlukinski,
We are already 5.5.7 and this problem is alive and well.
Need a solution (problem existed at least since 5.5.5)
benjaminsmith
Hi @dlukinski,
Can you tail the Apache error logs and then download the graph and post the output so we can review any errors being generated.
tail -f /var/log/httpd/error_log /var/log/httpd/ssl_error_log
Also, what browser are you using?
While it was not the error we we're seeing, there was an issue with report generation when upgrading to a newer version of jQuery in 5.5.4, that was resolved in 5.5.5. However, let's try to revert to the older version of jQuery and see if this resolve the problem.
Open up your config.inc.php file in /usr/local/nagiosxi/html/and add this stetting to the end of the file:
$cfg['old_browser_compat'] = 1;
Then restart Nagios:
service nagios start
dlukinski
Post by dlukinski »
benjaminsmith wrote:Hi @dlukinski,
This got resolved by the recent 5.5.9 update
Please close the thread
benjaminsmith
Hi @dlukinski,
Thanks for update. Closing topic.
