Hi All,
We are not receiving tickets for the Nagios Critical Alerts.Some hosts are able to send alert and we receive tickets in ServiceNow for them but for the rest of the hosts/services we are only receiving alerts in Nagios and there is no mail in Nagios mailbox and hence no ticket in ServiceNow.
Suggest what can be done?
Thanks & Regards
Hoegh.
Nagios is unable to send mails to mailbox & generate tickets
benjaminsmith
Re: Nagios is unable to send mails to mailbox & generate tic
Hi @hoegh,
I've read through some of your previous posts and it looks like you've had a few issues with ServiceNow ticket creation. First of all, were you ever able to get it setup and working properly?
Have you checked the nagios log file to see if the alerts were sent?
Go to end of /usr/local/nagios/var/nagios.log for the host or service, you should see a line like
Please let me know.
Did you assign the ServiceNow user to the host or service object ( see: https://support.nagios.com/kb/article.php?id=552 ).there is no mail in Nagios mailbox and hence no ticket in ServiceNow.
[1476416283] SERVICE NOTIFICATION: servicenow;localhost;Service Status - ntpd;UNKNOWN;notify-service-by-snt;ntpd is stopped
Hi Benjaminsmith,
Service Now host has already been assigned to the host.
And we did not found any such line at the end of /usr/local/nagios/var/nagios.log for the host or service.
Let us know what can be done now?
Thanks & Regards
Hoegh.
Thanks & Regards
Hoegh.
Höegh
Höegh
while verification in nagios CCM , getting following error , please let us know solution.
Error: There are no services defined!
Error: There are no hosts defined!
Error: Service notification command 'xi_service_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Error: Host notification command 'xi_host_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Error: Global host event handler command 'xi_host_event_handler' is not defined anywhere!
Error: Global service event handler command 'xi_service_event_handler' is not defined anywhere!
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 0 services.
Checked 0 hosts.
Checked 0 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 0 contact groups.
Checked 0 commands.
Checked 1 time periods.
Checked 0 host escalations.
Checked 0 hosts
Checked 0 host dependencies
Checked 1 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 6
***> One or more problems was encountered while running the pre-flight check...
directives and data definitions. If you are upgrading from a previous
Nagios Core 4.4.2
License: GPL
Checking objects...
Checked 0 services.
Checked 0 hosts.
Checked 1 contacts.
Checked 0 commands.
Checked 0 hosts
Total Warnings: 0
Total Errors: 6
Höegh
Höegh
benjaminsmith
Hello @hoegh,
There's an issue with your configuration as nothing is defined:
Aslso, it would be very helpful for us if you can upload or PM me your system profile. To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and upload it to a cloud storage of your choice. You can share a link with me in a personal message.
After you upload the profile please post something in this thread to bring it up in the support queue.
Thank you.
Are you able to roll back to a previous configuration snapshot that is working as intended (other than the ServiceNow issue)? Go to Configure > Quick Tools > Configuration Snapshots.Error: There are no services defined!
Checked 0 services.
Checked 0 hosts.
Thank you.
It was found that Config files were corrupted after upgrading Nagios to 5.5.7.
So we reverted back the Nagios to its earlier Snapshot & waiting for next upgrade from Nagios.
For Now everything working as expected, So please close this thread.
Thanks & Regards
Vipin
Hoegh
Thanks & Regards
Vipin
Hoegh
Höegh
Höegh
benjaminsmith
Hello @hoegh,
https://www.nagios.com/downloads/nagios-xi/change-log/
Great. Nagios 5.5.8 will mostly likely be released this week. When available, you can can review the Nagios XI changelog for more information.For Now everything working as expected, So please close this thread
