plugin: check_snmp_storage
krystwie
Post by krystwie »
Hello, I have a problem with plugin: check_snmp_storage
One serwer have SAS storage (10TB capacity, 1TB free)
Nagios shows that:
F: Label:BACKUP_VOL Serial Number 88c93c8: 116%used(-7309626MB/-6284956MB) (>90%) : CRITICAL
Why?
Re: plugin: check_snmp_storage
Are you using the "default check_snmp_storage.pl", that comes with Nagios XI, or you are using a custom plugin? If you are using a different plugin, can you post the download link? We will try to recreate the problem. Thanks!
krystwie
Post by krystwie »
http://nagios.manubulon.com/check_snmp_storage.pl
# Version : 1.3.3
# Date : Jun 1 2007
# Author : Patrick Proy ( patrick at proy.org)
# Help : http://nagios.manubulon.com
# Licence : GPL - http://www.fsf.org/licenses/gpl.txt
# TODO :
# Contribs : Dimo Velev, Makina Corpus, A. Greiner-Bär
Can you run the actual command that you are using in terminal and show us the command and the output?
krystwie
Post by krystwie »
I don't know how run command in terminal
Please tell me, then I try
krystwie
Post by krystwie »
OK, Now I know
plwawsnagios:/usr/lib/nagios/plugins# ./check_snmp_storage -H 172.17.18.21 -C public -m F -w 80 -c 90
F:\ Label:BACKUP_VOL Serial Number 88c93c8 : 110 %used (-6942767MB/-6284956MB) (< 90) : CRITICAL
you might need to add --v2c to the request for counters that large
./check_snmp_storage -H 172.17.18.21 -C public -m F -w 80 -c 90 --v2c
krystwie
Post by krystwie »
Sorry, not working:
plwawsnagios:/usr/lib/nagios/plugins# ./check_snmp_storage -H 172.17.18.21 -C public -m F -w 80 -c 90 --v2c
F:\ Label:BACKUP_VOL Serial Number 88c93c8: 108%used(-6759166MB/-6284956MB) (>90%) : CRITICAL
I'm not sure why you are getting this but it may be because of the type of device you are monitoring and it's use of various technologies (ie RAID. etc). It may be more appropriate to find a plugin specifically for SAS devices
