Hi All,
I'm new here and I'm looking for any information or help I can get on Nagios Core. I have to prepare a DDC( Detailed Design Specification) for our team and will appreciate any help I can get. Thanks in advance.
I would suggest you start reading on Nagios. I would like for you to write a DDS for Nagios. Since it`s open source, there`s plenty of documentation and videos of the product online. We need to build knowledge on the tool within the team.
The architecture should be simple as usually, a one server deployment is the norm.
GlennK
Nagios Core information
benjaminsmith
Re: Nagios Core information
Hi @ggkavana
I would start be taking a look at the Nagios Core documentation and GitHub repository.
Nagios Core
https://assets.nagios.com/downloads/nag ... n/toc.html
Nagios Enterprises / Core @Github
https://github.com/NagiosEnterprises/nagioscore
Nagios Core
Thanks....that's a lot of information....can you direct me to somewhere where I can get enough information to write a brief Design Specification? We're from a CA Spectrum shop so we have some idea how a monitoring tool works.benjaminsmith wrote:Hi @ggkavana
Nagios Core
benjaminsmith
Hello ggkavana,
Some detail would be helpful. What are you working on?
