Monitoring service of remote linux server
t3dus
Post by t3dus »
So I have my nagios server at my house monitoring some stuff on an external linux server but I'm not quite sure how I can monitor a service of a remote linux server?
For windows I'd probably do something like this but what would I do for linux services monitoring?
        host_name               Matt-i7
        service_description     Explorer
        check_command           check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
        notifications_enabled           0
I have a service called "furybot" which is basically just a Budabot chat bot i use for a game I play. it shows up in htop like this
However I'm not sure how i can monitor that in Nagios.
As you can see below it's a custom service I setup.
Re: Monitoring service of remote linux server
For monitoring services on a Linux machine you will need to install an agent on the Linux servers such as NCPA
See the following link for documentation and download instructions
https://www.nagios.org/ncpa/
t3dus
Post by t3dus »
scottwilkerson wrote:For monitoring services on a Linux machine you will need to install an agent on the Linux servers such as NCPA
Well I knew that and I have no problem doing that. My question is trying to figure out how my definition would look for a custom service like that.
There is a services section here
https://www.nagios.org/ncpa/help.php#api-modules-services
something like this
./check_ncpa.py -H <your IP> -t '<your token>' -M 'services' -q 'service=Dhcp,status=running'
NCPA also has a web UI on servers it is installed on that can show what is available to be monitored in the API tab
https://IP_ADDRESS:5693/
