After upgrade to latest version bulk cloning and import wizard no longer clones templates, variables, URLs, et al - hoses our configuration and we have to roll back:
Your Nagios XI installation is up to date.
Latest Available Version: 5.5.7
Installed Version: 5.5.7
Last Update Check: 12/05/2018 23:13:01
Bulk Host Cloning and Import
Re: Bulk Host Cloning and Import
After consulting with the developers about the cause of this, we did come up with a cause and that is the file format changes slightly in the newer versions and need to be re-written to be parsed correctly.
Lets to the following. Remove the erroneous configs for the host/services, in the CCM.
Then
CCM -> Tools -> Config File Management
Delete Files
Write Configs
Verify Files
Restart Nagios Core
This will reset the configs
Now, the Bulk Host Import Wizard should work correctly.
Then
Delete Files
Write Configs
Verify Files
Restart Nagios Core
bbackstrom
That looks to have done the trick - thanks!
Great! Locking threadbbackstrom wrote:That looks to have done the trick - thanks!
