Passive Service Acknowledgement
greener
Post by greener »
Dear Gents,
When I do the Critical Passive Service Acknowledgement, it does not clear from the Critical Passive (Status) and It is added to the Critical Acknowledgement, but when I do acknowledgment on a Critical Active Service, it clear from the Critical Active (Status) and added to Critical Acknowledgement.
Is it the normal behavior of the Critical Passive service when acknowledge it will not clear from Critical Passive (Status)?
Ronald
Re: Passive Service Acknowledgement
What version of Nagios Core are you running?
Can you provide the steps you took to view the services in the GUI so we can try and recreate what you are seeing?
greener
Post by greener »
Hi TGRIEP,
I'm using Nagios Core 4.4.2 and Thruk 2.24-2.
TAC View
Services
4 Critical
--- 1 Unhandled Problems
|--- Site 1 Enclosure1 OA2 = CRITICAL (this is active check)
(after acknowledging, it will transfer to Acknowledged section)
--- 0 Acknowledged
--- 3 Passive
|--- SQL1 Base-Disk H Usage
(after acknowledging, status change to acknowledge but remain to Passive section
and added to Acknowledged section)
|--- SQL1 Base-Disk I Usage
|--- SQL1 Base-Disk J Usage
Active Check Acknowledgement:
When I acknowledged the "Site 1 Enclosure1 OA", then it clear the 1 Unhandled Problems and added 1 to Acknowledged status.
Passive Check Acknowledgement:
When I acknowledged the "SQL1 Base-Disk H Usage", it will add this to the "Acknowledged section" and it will not clear from the "Passive", but the status "acknowledged" is on to this "SQL1 Base-Disk H Usage" service.
I don't have Thruk installed but if I go the Tactical Overview menu and click on the Critical Service link, it does show both the Acknowledged Active and Passive Checks and that they have been Acknowledged.
If I click on the Services link under the Problems menu when the passive check is unhanded, it shows up correctly.
If I acknowledge it, it is removed from the Unhandled Service Problems menu like it should be.
So the default menus seem to be working.
Have you searched Thruk's site to see if there are and known bugs for this?
greener
Post by greener »
tgriep wrote:I don't have Thruk installed but if I go the Tactical Overview menu and click on the Critical Service link, it does show both the Acknowledged Active and Passive Checks and that they have been Acknowledged.
Hello TGRIEP,
All Passive checks that has been acknowledged, why it is not remove from the "Services-Critical-Disabled"? It is already added to "Services-Critical-Acknowledge".
The Active checks that has been acknowledged, it is removed from the "Services-Critical-Unhandled" and added to "Services-Critical-Acknowledge".
It is not possible to have the Passive checks when acknowledged be remove from the "Services-Critical-Unhandled,Services-Critical-disabled" and add to "Critical-Services-Acknowledge"
The issue is with the Thruk interface. It is not removing the Acknowledged check from the menu. The default Nagios interface does work like you want and remove the passive acknowledged service from the menu.
Please go to the Thruk site and file the issue there.
https://github.com/sni/Thruk/issues
