Hi Team,
We were running Nagios Xi 5.4.2, today we upgraded to version 5.5.7.
After upgrade we had a issue in set mongo db monitoring as it was giving alert as below.
We replaced upgraded "check_mongodb.py" with earlier version of file & all started working as earlier.
Please let us know what is causing this issue.
Regards,
Rohan
Mongo DB monitoring stopped working after upgrade
npolovenko
- Support Tech
Re: Mongo DB monitoring stopped working after upgrade
Hello, @lrnnetops. Perhaps you need to update the pymongo version.
What is the OS on the server?pip install --upgrade pymongo
