I would like to utilize this plugin to do a check on a few mailboxes and have the system report when they fall out of the stated variable number. I imported it and expected to see the service listed in the check command area however, it's no listed as a service. How do i set this up to work with Nagios XI? There are no instructions for this plugin...
Need help with plugin check_unread_mails.pl
bolson
Re: Need help with plugin check_unread_mails.pl
Hello Demi,
I've attached a document for implementing an external plugin in Nagios XI. The method is the same for all plugins. I've also included a link to the plugin on exchange which provides information on the required arguments.
https://exchange.nagios.org/directory/P ... ls/details
Let me know if you have any additional questions.
Thank you for visiting the Nagios Support Forum.
Thank you i will take a look at this info.
bolson
Let me know if you're successful so that I may close the thread.
Thank you again!
Thank you again!
