This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
benhank
Posts: 1264 Joined: Tue Apr 12, 2011 12:29 pm
Post
by benhank » Tue Dec 11, 2018 12:25 pm
Hey guys
i
I happened to run
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
while doing an apply config. The apply config ran and completed quickly, however this was the results:
CMDLINE=php /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncall
PHP Notice: Undefined variable: err in /usr/local/nagiosxi/html/includes/compon ents/nagiosbpi/api_tool.php on line 146
CMD: syncall
MSG: Could not get data for objects. NDO or Core may not be running.
OUTPUT=MSG: Could not get data for objects. NDO or Core may not be running.
Should I be concerned about this?
this is on my Nagios XI 5.5.7 server.
Proudly running:
Nagios Network Analyser
Nagios Fusion
npolovenko
Posts: 3457 Joined: Mon May 15, 2017 5:00 pm
Post
by npolovenko » Tue Dec 11, 2018 1:33 pm
@benhank , What is the output of:
service nagios status
service ndo2db status
Also, please run: ps -ef > /tmp/support.txt and upload the support.txt file from the /tmp/ folder.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
benhank
Post
by benhank » Tue Dec 11, 2018 2:13 pm
the results are a little disturbing....
[root@lkennagiost01 ~]# service nagios status
>=D
[root@lkennagiost01 ~]# service ndo2db status
you're screwed bro...
nah jk here you go:
nagios (pid 8913) is running...
ndo2db (pid 8821) is running...
Proudly running:
Nagios Fusion
npolovenko
Post
by npolovenko » Tue Dec 11, 2018 4:09 pm
@benhank , Can you upload this config file?
/usr/local/nagiosxi/html/includes/components/nagiosbpi/bpi.conf
Privacy Policy .
benhank
Post
by benhank » Wed Dec 12, 2018 9:29 am
here you go
Proudly running:
Nagios Fusion
npolovenko
Post
by npolovenko » Wed Dec 12, 2018 11:37 am
@benhank No, wrong file. I need to see the bpi.conf. It's in the same folder.
Privacy Policy .
benhank
Post
by benhank » Wed Dec 12, 2018 11:49 am
WHOOPS! there you go
Proudly running:
Nagios Fusion
npolovenko
Post
by npolovenko » Wed Dec 12, 2018 4:55 pm
@benhank , I spoke to my colleagues and that PHP notice likely means that when you restarted the Core/applied configuration ndo hasn't gotten in sync with the BPI component(for a short period of time). This notice is normal and can be ignored.
Privacy Policy .
benhank
Post
by benhank » Thu Dec 13, 2018 10:24 am
Awesome thanks for the all the help man!
Proudly running:
Nagios Fusion
npolovenko
Post
by npolovenko » Thu Dec 13, 2018 1:41 pm
@benhank , You're welcome!
Privacy Policy .
