Nagios Agent
jsalsbury
Nagios Agent
Post by jsalsbury »
Good afternoon,
We are working on getting the Nagios agent deployed to a few Windows and Linux servers in our environment. Are there any specific commands we can use to make sure they are reporting in properly. As well is there a way to tell in the gui if an agent is checking in properly.
thanks
J
Re: Nagios Agent
What agent are you deploying? Many are actively checked from Nagios and do not "report in", but Nagios gets results when it performs a check.
This would be seen in the Nagios UI where the last check time is within the last few minutes.
