Config Verification fails
I started receiving an error after making a change to the contact for Alerting. Config verification fails. Was working fine until I tried adding emails into the additional address fields. I have tried resetting permissions, restarting services, restarting server. None of those worked. Obviously cant manually edit the contacts.cfg file. Here is the error output from the check configuration option in Admin tools.
Error: Template '' specified in contact definition could not be not found (config file '/usr/local/nagios/etc/contacts.cfg', starting on line 14)
I am on 2011R2.2 on the Nagios VM
Nagios XI
32 bit VM Image - 2011 R2.2
Re: Config Verification fails
One of your contacts must have a template specified that doesn't exist.
Go to Configure -> Core Config Manager -> Contacts -> Modify Contact (select one at a time) -> Misc Settings
We want to look at what is specified under "Additional templates"
Either we have a template name that no longer exists or blank or something.
If you cannot find it that way, or if you have a ton of contacts you can download the bad configuration from
Configure -> Core Config Manager -> Configuration Snapshots
and download the latest snapshot tarball that has the Config Error
From here you can open the contacts.cfg and look at line 14 to see which contact is having the problem.
I had tried adding email addresses into the Addon Address 1,2, and 3, applied the config and then decided to do the notifications a different way. After I removed the email addresses from the Addon address fields and went to apply the config, it failed. Now whenever I try to apply the config, it bombs out.
The misc settings -> additional templates have nothing in them but if I look in the fields in the contacts.cfg file, there is nothing there, and in the old version from the last successful apply, there was nothing in them either.
Here is the current contacts.cfg file output
define contact {
contact_name IT Support
alias XX XXXXXX IT Support
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period workhours
service_notification_period workhours
host_notification_options d
service_notification_options c
host_notification_commands notify-host-by-email
service_notification_commands notify-service-by-email
retain_status_information 1
email xxxxx@xxxx.com
address1 xxxxxx@xxxx.com.com
address2 rxxxxxxx@xxxx.com
address3 szxxxxxx@xxxx.com
define contact {
contact_name nagiosadmin
alias Nagios Administrator
host_notification_period nagiosadmin_notification_times
service_notification_period nagiosadmin_notification_times
host_notification_options d,u,r,f,s
host_notification_commands xi_host_notification_handler
service_notification_commands xi_service_notification_handler
email nagios@localhost
use generic-contact,xi_contact_generic
And Here is the old working contacts.cfg file setup(the setup that I want to return to). I obviously removed the email addresses just for cleanliness.
define contact {
alias US Vision IT Support
can_submit_commands 1
email XXXXXXXXXX@xsxxx.com
define contact {
Thanks again
define contact {
define contact {
define contact {
define contact {
Thanks again
Nagios XI
If you go to
Configure -> Core Config Manager -> Templates -> Contacts Templates
Do you have both generic-contact and xi_contact_generic ?
AND
Are both of them marked Active = Yes ?
AND
Yes they are both there and active.
Nagios XI
Go to the Core Config Manager->Alerting->Contacts->IT Support->Modify->Misc Settings tab->Additional templates and add "xi_contact_generic" template. Save. Apply Configuration.
Also, run the Write Config Tool and show us the output:
Core Config Manager->Tools->Write Config Files
Tried the first step and it failed.
Here is the output from "write additional data"
Write timeperiods.cfg ...
Configuration file successfully written!
Write commands.cfg ...
Write contacts.cfg ...
Write contactgroups.cfg ...
Write contacttemplates.cfg ...
Write servicedependencies.cfg ...
Write hostdependencies.cfg ...
Write serviceescalations.cfg ...
Write hostescalations.cfg ...
Write serviceextinfo.cfg ...
Write hostextinfo.cfg ...
Output from "Check configuration Files"
I've omitted the rest of the output because I don't think you want to see a giant wall of text for every host and cfg file that we have(over 500 at this point)
Nagios XI
Open the contacts.cfg in a text editor and see what you have on (or around) line 14 that's causing the problem.
vi /usr/local/nagios/etc/contacts.cfg
:set number
line 14 is
define contact {
the notifications work but they send them to the wrong address. and its not all of the hosts that are sending them to the wrong address.
is there a way to just manually update the MySql database so that it gets the proper information and then it will just push it into the contacts.cfg ?
define contact {
Nagios XI
Did you try this?
Also, go to the Core Config Manager->Alerting->Contacts, click on the "Download" button, save the file and post it, so we can take a look at it.
