Failed to install Oracle Plugin
omarita
Post by omarita »
Dear Support,
I hope it's the right forum section. I installed the Nagios XI Virtual Machine, which works well. The version from system info is:
System
Nagios XI version: 5.5.8
XI installed from: ova
XI UUID: 761a563e-ad9e-4ace-8f6e-b882532fcba8
Release info: localhost.localdomain 3.10.0-957.1.3.el7.x86_64 x86_64
CentOS Linux release 7.6.1810 (Core)
I'm trying to install the Oracle client&plugin to monitor some Oracle servers, following this guide:
When I run oracleinstall, I end up with a test error:
CPAN.pm: Building Z/ZA/ZARQUON/DBD-Oracle-1.76.tar.gz
Test Summary Report
t/26exe_array.t (Wstat: 512 Tests: 0 Failed: 0)
Non-zero exit status: 2
Parse errors: No plan found in TAP output
Files=41, Tests=21, 6 wallclock secs ( 0.24 usr 0.11 sys + 4.54 cusr 1.18 csys = 6.07 CPU)
Result: FAIL
Failed 1/41 test programs. 0/21 subtests failed.
make: *** [test_dynamic] Error 255
/usr/bin/make test -- NOT OK
//hint// to see the cpan-testers results for installing this module, try:
reports ZARQUON/DBD-Oracle-1.76.tar.gz
Running make install
make test had returned bad status, won't install without force
I don't know if you need more logs.
Can you help me please?
Mario.
omarita
Re: Failed to install Oracle Plugin
Post by omarita »
My fault,
I looked better at documentation screenshot and the Oracle Instant Client to download were the 12.1 not the 12.2. I uninstalled the 12.2 rpms and restarted oraclelinstall.sh and everything went well.
Thanks, anyway.
Regards,
Mario.
omarita wrote:My fault,
Thanks, anyway.
Regards,
Mario.
Glad you were able to get it working
Locking thread
