Service notification command executed before macros updated?
johndorm
Post by johndorm »
I have a service notification command for a contact that passes $SERVICEDOWNTIME$ to my script.
$SERVICEDOWNTIME$ is supposed to be
A number indicating the current "downtime depth" for the service. If this service is currently in a period of scheduled downtime, the value will be greater than zero. If the service is not currently in a period of downtime, this value will be zero.
I also have notifications enabled for scheduled downtime, however, when my script executes for the scheduled downtime event, $SERVICEDOWNTIME$ gets passed with a value of 0 still.
It's unclear to me how I would get this service notification command to delay long enough for the macro to be updated. Maybe insert another service notification command (like /bin/sleep 5) prior to my script? Do multiple commands wait for the previous one to complete before executing for notification commands?
Thanks in advance.
johndorm
Re: Service notification command executed before macros upda
Post by johndorm »
Nevermind.
I found a macro that will work....$NOTIFICATIONTYPE$ will give me a sufficient value on downtime start/stop/cancel.
Thanks!
npolovenko
Post by npolovenko »
Hi, @johndorm. Thanks for the update! Are we good to lock this thread as resolved?
johndorm
Post by johndorm »
Absolutely. Thanks.
benjaminsmith
Post by benjaminsmith »
Closing. Thank you for using the Nagios Support Forum.
