apache - radius authentication cgi issues
pkolakkar
Post by pkolakkar »
I configured httpd to authenticate using radius for nagios in the httpd config file. Now I cant see hostgroups and service groups on the UI.
"It appears as though you do not have permission to view information for any of the hosts you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file."
is the error. Ive tried couple of things.
1. Changing contact name to the radius login
2. adding radius login name to the cgi.cfg
Also when I tried reverting to native authentication, even then it didnt work. The version of Nagios i am using is 3.3.1.
Any clues? Thanks guys.
pbk
