The user and group permissions on these directories are root:root, apache:apache, nagios:nagios.
# ls -ltr /usr/local
drwxr-xr-x 8 root root 79 Oct 16 14:37 nagios
drwxr-xr-x 10 nagios nagios 102 Oct 16 14:38 nagiosxi
drwxrwxr-x 4 nagios nagios 30 Oct 30 13:55 nsis
drwxr-xr-x 6 root root 227 Nov 9 11:07 nagiosmobile
drwxr-xr-x 5 apache apache 70 Nov 9 11:08 nagvis
drwxrwxr-x 7 nagios nagios 121 Nov 9 11:08 nrdp
The nagios directory has nagios:nagios and root:root.
# ls -ltr nagios
total 24
drwxrwxr-x 2 nagios nagios 4096 Nov 9 11:07 sbin
drwxrwxr-x 17 nagios nagios 4096 Nov 9 11:07 share
drwxr-xr-x 2 root root 192 Nov 9 11:08 bin
drwxrwxr-x 7 apache nagios 4096 Dec 14 11:24 etc
drwxrwxr-x 2 nagios nagios 8192 Dec 17 09:40 libexec
drwxrwxr-x 6 nagios nagios 270 Dec 17 13:58 var
i would like to copy all these folders/files from primary to secondary as a part of fail-over using Rsync. but in our organisation we are not allowed to ssh as root. Am i allowed to change the user permissions from root:root to nagios:nagios. Does it cause any issue to nagios performance?
Thanks.
User permissions on Nagios directories
Re: User permissions on Nagios directories
Changing a few of the directories should not affect performance, however there are files that are owned by root that need to remain that way or will not function, at a minimum:MOHANREDDY wrote:Am i allowed to change the user permissions from root:root to nagios:nagios. Does it cause any issue to nagios performance?
ls -l /usr/local/nagios/libexec/check_dhcp
ls -l /usr/local/nagios/libexec/check_icmphttps://assets.nagios.com/downloads/nag ... ios-XI.pdf
bolson
Hello MOHANREDDY,
In addition to what Scott has said, since the mode is read-execute for all users, you should be able to rsync these directories as an ordinary (non-privileged) user without changing permissions. You can run these command from a non-root account to test:
cd /usr/local
rsync -prl --specials nagios /tmp-
MOHANREDDY
scottwilkerson wrote:Changing a few of the directories should not affect performance, however there are files that are owned by root that need to remain that way or will not function, at a minimum:MOHANREDDY wrote:Am i allowed to change the user permissions from root:root to nagios:nagios. Does it cause any issue to nagios performance?I would recommend making a backup using the backup script and restoring on the secondaryCode: Select all
ls -l /usr/local/nagios/libexec/check_dhcp ls -l /usr/local/nagios/libexec/check_icmp
As you suggested, instead of copying files I tried to restore secondary server from primary server backup, and i ran reconfigure.sh, i ran into couple of errors.
#/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
PHP Warning: mysqli::mysqli(): (28000/1045): Access denied for user 'nagiosql'@'secondary_app_server' (using password: YES) in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 80
PHP Warning: mysqli::set_charset(): Couldn't fetch mysqli in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 81
PHP Warning: mysqli::query(): Couldn't fetch mysqli in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 82
PHP Warning: mysqli::query(): Couldn't fetch mysqli in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 99
PHP Warning: db::query(): Property access is not allowed yet in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 101
PHP Notice: Trying to get property of non-object in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 112
PHP Fatal error: Call to a member function free() on a non-object in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 117
Importing into the CCM failed!
i have database offloaded to a separate server, I tried to run repair databases script. i saw some errors.
# /usr/local/nagiosxi/scripts/repair_databases.sh
DATABASE: nagios
TABLE:
nagios.nagios_acknowledgements OK
nagios.nagios_commands OK
nagios.nagios_commenthistory OK
nagios.nagios_comments OK
nagios.nagios_configfiles OK
nagios.nagios_configfilevariables OK
nagios.nagios_conninfo OK
nagios.nagios_contact_addresses OK
nagios.nagios_contact_notificationcommands OK
nagios.nagios_contactgroup_members OK
nagios.nagios_contactgroups OK
nagios.nagios_contactnotificationmethods OK
nagios.nagios_contactnotifications OK
nagios.nagios_contacts OK
nagios.nagios_contactstatus OK
nagios.nagios_customvariables OK
nagios.nagios_customvariablestatus OK
nagios.nagios_dbversion OK
nagios.nagios_downtimehistory OK
nagios.nagios_eventhandlers OK
nagios.nagios_externalcommands OK
nagios.nagios_flappinghistory OK
nagios.nagios_host_contactgroups OK
nagios.nagios_host_contacts OK
nagios.nagios_host_parenthosts OK
nagios.nagios_hostchecks OK
nagios.nagios_hostdependencies OK
nagios.nagios_hostescalation_contactgroups OK
nagios.nagios_hostescalation_contacts OK
nagios.nagios_hostescalations OK
nagios.nagios_hostgroup_members OK
nagios.nagios_hostgroups OK
nagios.nagios_hosts OK
nagios.nagios_hoststatus OK
nagios.nagios_instances OK
nagios.nagios_logentries OK
nagios.nagios_notifications OK
nagios.nagios_objects OK
nagios.nagios_processevents OK
nagios.nagios_programstatus OK
nagios.nagios_runtimevariables OK
nagios.nagios_scheduleddowntime OK
nagios.nagios_service_contactgroups OK
nagios.nagios_service_contacts OK
nagios.nagios_service_parentservices OK
nagios.nagios_servicechecks OK
nagios.nagios_servicedependencies OK
nagios.nagios_serviceescalation_contactgroups OK
nagios.nagios_serviceescalation_contacts OK
nagios.nagios_serviceescalations OK
nagios.nagios_servicegroup_members OK
nagios.nagios_servicegroups OK
nagios.nagios_services OK
nagios.nagios_servicestatus OK
nagios.nagios_statehistory OK
nagios.nagios_systemcommands OK
nagios.nagios_timedeventqueue OK
nagios.nagios_timedevents OK
nagios.nagios_timeperiod_timeranges OK
nagios.nagios_timeperiods OK
Issued remote command 'mysqlcheck -f -r -u nagios -pnagios -h Database_server --port=3306 --databases nagios'
DATABASE: nagiosql
TABLE:
nagiosql.tbl_command
note : The storage engine for the table doesn't support repair
nagiosql.tbl_contact
nagiosql.tbl_contactgroup
nagiosql.tbl_contacttemplate
nagiosql.tbl_domain
nagiosql.tbl_host
nagiosql.tbl_hostdependency
nagiosql.tbl_hostescalation
nagiosql.tbl_hostextinfo
nagiosql.tbl_hostgroup
nagiosql.tbl_hosttemplate
nagiosql.tbl_info
nagiosql.tbl_lnkContactToCommandHost
nagiosql.tbl_lnkContactToCommandService
nagiosql.tbl_lnkContactToContactgroup
nagiosql.tbl_lnkContactToContacttemplate
nagiosql.tbl_lnkContactToVariabledefinition
nagiosql.tbl_lnkContactgroupToContact
nagiosql.tbl_lnkContactgroupToContactgroup
nagiosql.tbl_lnkContacttemplateToCommandHost
nagiosql.tbl_lnkContacttemplateToCommandService
nagiosql.tbl_lnkContacttemplateToContactgroup
nagiosql.tbl_lnkContacttemplateToContacttemplate
nagiosql.tbl_lnkContacttemplateToVariabledefinition
nagiosql.tbl_lnkHostToContact
nagiosql.tbl_lnkHostToContactgroup
nagiosql.tbl_lnkHostToHost
nagiosql.tbl_lnkHostToHostgroup
nagiosql.tbl_lnkHostToHosttemplate
nagiosql.tbl_lnkHostToVariabledefinition
nagiosql.tbl_lnkHostdependencyToHost_DH
nagiosql.tbl_lnkHostdependencyToHost_H
nagiosql.tbl_lnkHostdependencyToHostgroup_DH
nagiosql.tbl_lnkHostdependencyToHostgroup_H
nagiosql.tbl_lnkHostescalationToContact
nagiosql.tbl_lnkHostescalationToContactgroup
nagiosql.tbl_lnkHostescalationToHost
nagiosql.tbl_lnkHostescalationToHostgroup
nagiosql.tbl_lnkHostgroupToHost
nagiosql.tbl_lnkHostgroupToHostgroup
nagiosql.tbl_lnkHosttemplateToContact
nagiosql.tbl_lnkHosttemplateToContactgroup
nagiosql.tbl_lnkHosttemplateToHost
nagiosql.tbl_lnkHosttemplateToHostgroup
nagiosql.tbl_lnkHosttemplateToHosttemplate
nagiosql.tbl_lnkHosttemplateToVariabledefinition
nagiosql.tbl_lnkServiceToContact
nagiosql.tbl_lnkServiceToContactgroup
nagiosql.tbl_lnkServiceToHost
nagiosql.tbl_lnkServiceToHostgroup
nagiosql.tbl_lnkServiceToServicegroup
nagiosql.tbl_lnkServiceToServicetemplate
nagiosql.tbl_lnkServiceToVariabledefinition
nagiosql.tbl_lnkServicedependencyToHost_DH
nagiosql.tbl_lnkServicedependencyToHost_H
nagiosql.tbl_lnkServicedependencyToHostgroup_DH
nagiosql.tbl_lnkServicedependencyToHostgroup_H
nagiosql.tbl_lnkServicedependencyToService_DS
nagiosql.tbl_lnkServicedependencyToService_S
nagiosql.tbl_lnkServiceescalationToContact
nagiosql.tbl_lnkServiceescalationToContactgroup
nagiosql.tbl_lnkServiceescalationToHost
nagiosql.tbl_lnkServiceescalationToHostgroup
nagiosql.tbl_lnkServiceescalationToService
nagiosql.tbl_lnkServicegroupToService
nagiosql.tbl_lnkServicegroupToServicegroup
nagiosql.tbl_lnkServicetemplateToContact
nagiosql.tbl_lnkServicetemplateToContactgroup
nagiosql.tbl_lnkServicetemplateToHost
nagiosql.tbl_lnkServicetemplateToHostgroup
nagiosql.tbl_lnkServicetemplateToServicegroup
nagiosql.tbl_lnkServicetemplateToServicetemplate
nagiosql.tbl_lnkServicetemplateToVariabledefinition
nagiosql.tbl_lnkTimeperiodToTimeperiod
nagiosql.tbl_logbook
nagiosql.tbl_mainmenu
nagiosql.tbl_permission
nagiosql.tbl_permission_inactive
nagiosql.tbl_service
nagiosql.tbl_servicedependency
nagiosql.tbl_serviceescalation
nagiosql.tbl_serviceextinfo
nagiosql.tbl_servicegroup
nagiosql.tbl_servicetemplate
nagiosql.tbl_session
nagiosql.tbl_session_locks
nagiosql.tbl_settings
nagiosql.tbl_submenu
nagiosql.tbl_timedefinition
nagiosql.tbl_timeperiod
nagiosql.tbl_user
nagiosql.tbl_variabledefinition
Issued remote command 'mysqlcheck -f -r -u nagiosql -pnagiosql -h Database_server --port=3306 --databases nagiosql'
DATABASE: nagiosxi
TABLE:
nagiosxi.xi_auditlog
nagiosxi.xi_auth_tokens
nagiosxi.xi_cmp_trapdata
nagiosxi.xi_cmp_trapdata_log
nagiosxi.xi_commands
nagiosxi.xi_eventqueue
nagiosxi.xi_events
nagiosxi.xi_incidents
nagiosxi.xi_meta
nagiosxi.xi_options
nagiosxi.xi_sessions
nagiosxi.xi_sysstat
nagiosxi.xi_usermeta
nagiosxi.xi_users
Issued remote command 'mysqlcheck -f -r -u nagiosxi -pnagiosxi -h Database_server --port=3306 --databases nagiosxi'
nagios offloaded database repair succeeded
nagiosql offloaded database repair succeeded
nagiosxi offloaded database repair succeeded
I checked database connection from App server to database server, everything seems good.
# mysql -u nagios -p'nagios' -h secondary_database_server -e STATUS;
mysql Ver 15.1 Distrib 5.5.52-MariaDB, for Linux (x86_64) using readline 5.1
Connection id: 56310
Current database:
Current user: nagios@secondary_app_server
SSL: Not in use
Current pager: stdout
Using outfile: ''
Using delimiter: ;
Server: MariaDB
Server version: 5.5.52-MariaDB MariaDB Server
Protocol version: 10
Connection: secondary_database_server via TCP/IP
Server characterset: latin1
Db characterset: latin1
Client characterset: latin1
Conn. characterset: latin1
TCP port: 3306
Uptime: 1 day 21 hours 4 min 20 sec
Threads: 22 Questions: 945222 Slow queries: 0 Opens: 5296 Flush tables: 2 Open tables: 102 Queries per second avg: 5.825
]# mysql -u nagiosql -p'nagiosql' -h secondary_database_server -e STATUS;
Connection id: 56341
Current database:
Current user: nagiosql@secondary_app_server
SSL: Not in use
Using outfile: ''
Using delimiter: ;
Server: MariaDB
TCP port: 3306
Uptime: 1 day 21 hours 5 min 30 sec
Threads: 22 Questions: 945846 Slow queries: 0 Opens: 5296 Flush tables: 2 Open tables: 102 Queries per second avg: 5.826
# mysql -u nagiosxi -p'nagiosxi' -h secondary_database_server -e STATUS;
Connection id: 56375
Current database:
Current user: nagiosxi@secondary_app_server
SSL: Not in use
Using outfile: ''
Using delimiter: ;
Server: MariaDB
TCP port: 3306
Uptime: 1 day 21 hours 6 min 13 sec
Threads: 22 Questions: 946359 Slow queries: 0 Opens: 5296 Flush tables: 2 Open tables: 102 Queries per second avg: 5.828
Please help me what to check and where to check on this issue.
Thanks.
bolson
Does Nagios XI work as expected on the primary server? Are you running the reconfigure and repair scripts on the primary or secondary server? On the secondary server, did you make the necessary edits to /usr/local/nagiosxi/html/config.inc.php as defined in this doc?
https://assets.nagios.com/downloads/nag ... Server.pdf
MOHANREDDY
The primary works fine and i have ran the reconfigure and repair scripts on secondary server. I have followed all the steps defined in that doc. I have changed ip's in /usr/local/nagiosxi/html/config.inc.php as well as /usr/local/nagios/etc/ndo2db.cfg.bolson wrote:Does Nagios XI work as expected on the primary server? Are you running the reconfigure and repair scripts on the primary or secondary server? On the secondary server, did you make the necessary edits to /usr/local/nagiosxi/html/config.inc.php as defined in this doc?
bolson
These can safely be ignored as they are merely informational.note : The storage engine for the table doesn't support repair
On the other hand, these are more concerning:
The bottom Fatal error iappears to be the result of the reconfigure script being unable to connect using the credentials passed. At this point, without more information, I would have to ask you to doublecheck your configuration on the secondary server.PHP Warning: mysqli::mysqli(): (28000/1045): Access denied for user 'nagiosql'@'secondary_app_server' (using password: YES) in /usr/local/nagiosxi/html/includes/components/ccm/classes/db.class.php on line 80
MOHANREDDY
I have a question, can we restore everything except databases from the backups using restore script as we have replication between databases? i need a way to make secondary be in sync with secondary in respect to config files, other files/folders.
bolson
While in theory, the scenario you've described should work, there's no substitute for thorough testing to determine if things will work as expected.
