We are at Nagios XI 5.4.11 and I was trying to upgrade it to the latest version 5.5.8 last night but failed. I did it from the GUI, Quick upgrade and Manual upgrade following your instructions but all failed at the same place. The Nagios server has no problem connecting to Internet, including https://assets.nagios.com/.
xxxxxxxxxxxxxxxxxxxxxxxxxxx
*** Compile finished ***
You can now continue with the installation or upgrade process.
Read the PDF documentation (docs/NRPE.pdf) for information on the next
steps you should take to complete the installation or upgrade.
cd ./src/; make install-plugin
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
/bin/install -c -m 755 -d /usr/local/nagios/bin
/bin/install -c -m 755 ../uninstall /usr/local/nagios/bin/nrpe-uninstall
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/bin/install -c -m 775 -o nagios -g nagios check_nrpe /usr/local/nagios/libexec
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
cd ./src/; make install-daemon
/bin/install -c -m 755 nrpe /usr/local/nagios/bin
/bin/install -c -m 755 -d /usr/lib/tmpfiles.d
/bin/install -c -m 644 ../startup/tmpfile.conf /usr/lib/tmpfiles.d/nrpe.conf
/bin/install -c -m 644 startup/default-service /usr/lib/systemd/system/nrpe.service
UPGRADE: NRPE upgraded OK.
UPGRADE: NRDP is being upgraded...
UPGRADE: NRDP upgraded OK.
Finished updating Core, Plugins, NRPE, NRDP ...
Upgrading MySQL database for XI...
Removing Ajaxterm...
Installing new SSH Terminal...
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-
: manager
No package shellinabox available.
Error: Nothing to do
Upgrade to 5.5.8 failed
Re: Upgrade to 5.5.8 failed
Try commenting out the following section of code in the /tmp/nagiosxi/upgrade script:
as described in this post:
https://support.nagios.com/forum/viewto ... 0&start=20
Did this help?
# Uninstall ajaxterminal to install shellinabox
#rpmcheck=$(rpm -q Ajaxterm)
#if [ $? -eq 0 ]; then
# rpm -e Ajaxterm
# cp -f "$httpdconfdir/ssl.conf" "$httpdconfdir/ssl.conf.nagiosxibackup"
# sed -i '/## AJAXTERM #####################/,+12d' "$httpdconfdir/ssl.conf"
# rm -f $proddir/html/admin/ajaxterm.php
#fihttps://support.nagios.com/forum/viewto ... 0&start=20
Did this help?
This issue is fixed after I commented out both "# Uninstall ajaxterminal to install shellinabox" and "# Install new sshterminal if it needs to install it"
Yet, the upgrade stopped with the messages below. Does it look complete? From the web GUI, it look like it has been upgraded to 5.5.8. But can you double-check?
Your Nagios XI installation is up to date.
Latest Available Version: 5.5.8
Installed Version: 5.5.8
Last Update Check: 2018-12-18 15:52:06
--2018-12-18 15:45:05-- http://assets.nagios.com/downloads/supp ... ns.tar.bz2
Resolving assets.nagios.com (assets.nagios.com)... 72.14.181.71, 2600
:f03c:91ff:fedf:b821
Connecting to assets.nagios.com (assets.nagios.com)|72.14.181.71|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://assets.nagios.com/downloads/sup ... ns.tar.bz2 [following]
--2018-12-18 15:45:05-- https://assets.nagios.com/downloads/sup ... ns.tar.bz2
Connecting to assets.nagios.com (assets.nagios.com)|72.14.181.71|:443... connected.
Length: 8843 (8.6K) [application/x-bzip2]
Saving to: ‘snmptrap-bins.tar.bz2’
100%[===================================================================================================================================>] 8,843 --.-K/s in 0s
2018-12-18 15:45:05 (92.5 MB/s) - ‘snmptrap-bins.tar.bz2’ saved [8843/8843]
Updating snmptt.ini
cp: cannot stat ‘/etc/snmp/snmptt.ini’: No such file or directory
sed: can't read /etc/snmp/snmptt.ini: No such file or directory
Creating snmptrapd.conf
Adding the snmptt user to the nagios and nagcmd groups
usermod: user 'snmptt' does not exist
Modifying permissions
/bin/chown: cannot access ‘/etc/snmp/snmptt.conf’: No such file or directory
chmod: cannot access ‘/etc/snmp/snmptt.conf’: No such file or directory
/bin/chown: invalid user: ‘snmptt:snmptt’
chmod: cannot access ‘/var/spool/snmptt’: No such file or directory
chmod: cannot access ‘/var/log/snmptt’: No such file or directory
Adding firewall rules
FirewallD is not running
Set up the snmptt daemon to start automatically on boot
as well as starting it now
Failed to execute operation: No such file or directory
Updating snmptt.ini
I wonder if you are missing some of the required packages. Run the following command to install the snmp packages (if they are not installed yet):
then try rerunning the upgrade script with the "-f" flag:
Also, make sure to check if you have the epel repo added before running the above commands:
If epel is not added, you would need to add it to your system.
yum install snmptt net-snmp net-snmp-perl -yCode: Select all
cd /tmp/nagiosxi
./upgrade -fCode: Select all
yum repolistBe sure to check out our Knowledgebase for helpful articles and solutions!
You are right! It turned out epel repo was disabled. I enabled it and installed snmptt, net-snmp, and net-snmp-perl. Then I ran "./upgrade -f". This time, the upgrade seems to be complete. I attached the upgrade log. Could you please double-check to see if it is actually complete? Thanks much!
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 409 services.
Checked 36 hosts.
Checked 4 host groups.
Checked 0 service groups.
Checked 20 contacts.
Checked 5 contact groups.
Checked 132 commands.
Checked 26 time periods.
Checked 0 host escalations.
Checked 36 hosts
Checked 0 host dependencies
Checked 26 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
> Return Code: 0
Nagios XI Upgrade Complete!
> Output:
Nagios Core 4.4.2
License: GPL
Checking objects...
Checked 36 hosts.
Checked 36 hosts
Total Warnings: 0
Total Errors: 0
> Return Code: 0
The log looks fine - it seems that this time you were able to finish the upgrade successfully. Is it safe to close this topic now? Let us know if you have any further questions. Thank you!
Now that you checked the log and confirmed the upgrade finished successfully, yes you can close out this ticket. Thanks a lot for your prompt help!
You are very welcome!
I am locking the thread.
