Limiting logging to /var/log/messages
BackNBlack
Post by BackNBlack »
I would like to eliminate some log messages going to /var/log/messages and would like to know the best way to do this. These messages are written every 5 minutes and don't seem too important to me but what do I know.
How can I turn these off/filter them out without affecting the proper functioning of my Network Analyzer?
Dec 18 16:55:00 myhost nfcapd[2550]: Run expire on '/usr/local/nagiosna/var/myrouter/flows'
Dec 18 16:55:00 myhost nfcapd[2550]: Limits: Filesize <none>, Lifetime 86400 = 1.0 days, Watermark: 95%
Dec 18 16:55:00 myhost nfcapd[2550]: Current size: 1142784 = 1.1 MB, Current lifetime: 83400 = 23.2 hours, Number of files: 279
Dec 18 16:55:00 myhost nfcapd[2550]: expire completed - nothing to expire.
Dec 18 16:55:00 myhost nfcapd[2550]: launcher child exit 1 children.
Dec 18 16:55:00 myhost nfcapd[2550]: launcher child 7891 exit status: 0
Dec 18 16:55:00 myhost nfcapd[2550]: launcher waiting children done. 0 children
Dec 18 16:55:01 myhost nfcapd[2594]: Ident: '8' Flows: 795, Packets: 0, Bytes: 218457798, Sequence Errors: 0, Bad Packets: 0
Dec 18 16:55:01 myhost nfcapd[2594]: Signal launcher
Dec 18 16:55:01 myhost nfcapd[2594]: Total ignored packets: 0
Dec 18 16:55:01 myhost nfcapd[2595]: Launcher: fork child.
Dec 18 16:55:01 myhost nfcapd[2595]: Launcher: child exec done.
Dec 18 16:55:01 myhost nfcapd[2595]: Run expire on '/usr/local/nagiosna/var/myfw/flows'
Dec 18 16:55:01 myhost nfcapd[2595]: Limits: Filesize <none>, Lifetime 86400 = 1.0 days, Watermark: 95%
Dec 18 16:55:01 myhost nfcapd[2595]: Current size: 4083712 = 3.9 MB, Current lifetime: 81900 = 22.8 hours, Number of files: 274
Dec 18 16:55:01 myhost nfcapd[2595]: expire completed - nothing to expire.
Dec 18 16:55:01 myhost nfcapd[2595]: launcher child exit 1 children.
Dec 18 16:55:01 myhost nfcapd[2595]: launcher child 7901 exit status: 0
Dec 18 16:55:01 myhost nfcapd[2595]: launcher waiting children done. 0 children
Re: Limiting logging to /var/log/mesages
Try this, edit the /etc/rsyslog.conf file and above this line
*.info;mail.none;authpriv.none;cron.none                /var/log/messages
add this line
if $programname == 'nfcapd' then stop
So it looks like this
Then restart rsyslog by running
service rsyslog restart
That should stop the logging of the messages and it will not affect the operation of the Network Analyzer.
BackNBlack
That did not work :(
It could be that your version of rsyslog does not support that feature.
I tested it on Centos 7 and rsyslogd version 7.4.7 and it worked.
Find out which version of rsyslogd you are running and search the internet to see if it supports that feature.
BackNBlack
Hmm,
I'm using rsyslog-5.8.10-10.el6_6.x86_64 on a CentOS 6.9 system. I'll look around to see if it supports that command or not.
I found another way to block rsyslog from logging those messages that may work for that version.
Add a config to /etc/rsyslog.d folder.
Call it nfcapd.conf
Put the following in it and restart rsyslog
if $programname == 'nfcapd' then {
                stop
Let us know it if works.
If not and you figure it out, please post your findings here.
BackNBlack
Sorry, it is still not working, here is the error i am getting from the change;
[root@myhost rsyslog.d]# pwd
/etc/rsyslog.d
[root@myhost rsyslog.d]# cat  nfcapd.conf
                stop
[root@myhost rsyslog.d]# service rsyslog status
rsyslogd (pid  1664) is running...
[root@myhost rsyslog.d]# service rsyslog restart
Shutting down system logger:                               [  OK  ]
Starting system logger:                                    [  OK  ]
Jan 24 12:32:39 myhost kernel: Kernel logging (proc) stopped.
Jan 24 12:32:39 myhost rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="1664" x-info="http://www.rsyslog.com"] exiting on signal 15.
Jan 24 12:32:39 myhost kernel: imklog 5.8.10, log source = /proc/kmsg started.
Jan 24 12:32:39 myhost rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="18516" x-info="http://www.rsyslog.com"] start
Jan 24 12:32:39 myhost rsyslogd: the last error occured in /etc/rsyslog.d/nfcapd.conf, line 1:"if $programname == 'nfcapd' then {"
Jan 24 12:32:39 myhost rsyslogd: warning: selector line without actions will be discarded
Jan 24 12:32:39 myhost rsyslogd-3000: unknown priority name "" [try http://www.rsyslog.com/e/3000 ]
Jan 24 12:32:39 myhost rsyslogd: the last error occured in /etc/rsyslog.d/nfcapd.conf, line 2:"                stop"
Jan 24 12:32:39 myhost rsyslogd: the last error occured in /etc/rsyslog.d/nfcapd.conf, line 3:"}"
I noticed another file in the directory that i thought might help me to figure this out but it still is very confusing to me. Perhaps someone else can look at it as a reference.
cat spice-vdagentd.conf
# A template to for higher precision timestamps + severity logging
$template SpiceTmpl,"%TIMESTAMP%.%TIMESTAMP:::date-subseconds% %syslogtag% %syslogseverity-text%:%msg:::sp-if-no-1st-sp%%msg:::drop-last-lf%\n"
:programname, startswith, "spice-vdagent"	/var/log/spice-vdagent.log;SpiceTmpl
Your running rsyslog 5.8.10 and the rules formatting are different on newer versions of rsyslog which I used to test that rule.
Remove the existing rule and change it to this.
:programname,isequal,"nfcapd" stop
BackNBlack
Thanks for quick reply, one question.
Put both of these lines in the /etc/rsyslog.conf file in the rules section?
you would create a new file such as /etc/rsyslog.d/nfcapd.conf and add it there
then restart rsyslogd
service rsyslogd restart
