I am getting the following message in the logstash logs.
{:timestamp=>"2018-12-19T08:34:50.357000+0800", :message=>"Attempted to send a bulk request to Elasticsearch configured at '[\"http://localhost:9200\"]',
but Elasticsearch appears to be unreachable or down!", :error_message=>"Connection reset", :class=>"Manticore::SocketException", :level=>:error}
almost every 2sec generating this message
also, I can see the following message in the /var/log/messages ...
Dec 19 10:05:34 pl-pd-nls1 logstash: Dec 19, 2018 10:05:34 AM org.apache.http.impl.execchain.RetryExec execute
Dec 19 10:05:34 pl-pd-nls1 logstash: INFO: Retrying request to {}->http://localhost:9200
Dec 19 10:05:35 pl-pd-nls1 logstash: Dec 19, 2018 10:05:35 AM org.apache.http.impl.execchain.RetryExec execute
Dec 19 10:05:35 pl-pd-nls1 logstash: INFO: I/O exception (java.net.SocketException) caught when processing request to {}->http://localhost:9200: Connection reset
This message also generating almost every 2 sec.
also, I can see the following message in the elasticsearch logs.
[2018-12-19 10:14:06,646][WARN ][http.netty ] [12c3bc39-1cf0-4dfd-a2c8-d9ec25fd25e8] Caught exception while handling client http traffic, closing connection [id: 0x848a19a0, /127.0.0.1:47880 => /127.0.0.1:9200]
org.elasticsearch.common.netty.handler.codec.frame.TooLongFrameException: HTTP content length exceeded 104857600 bytes.
However as I checked, logstash and elasticsearch still running. I am able to telnet localhost 9200 too. I have core 4 CPU in my cluster and I can see
CPU usage is varying 100 - 200% always.
As I suspect, I am getting quite a high payload of syslog data. But it seems, we need this type of logs to be stored in NLS.
Can you please help me to resolve this issue? What configurations need to be optimized?
Thank you
Luke.
npolovenko
- Support Tech
Re: Elasticsearch appears to be unreachable or down!
Hello, @lukedevon. Could you send in your System Profile so I can review it?
Attached is a script to gather a profile from the command line.
Copy the script to the machine and from the command line run:
It will generate a file called system-profile.tar.gz in /tmp.chmod 755 profile.sh
./profile.sh
Hi
Thanks for the support. I PM you the files.
Current status of mem usage;
total used free shared buff/cache available
Mem: 32012 18902 250 129 12859 12433
Swap: 65531 0 65531
About to die.
Regards
Luke.
Swap: 65531 0 65531
About to die.
Regards
Luke.
npolovenko
- Support Tech
@lukedevon, Let's increase the http content length setting in the:
Open the file with a text editor, and find the following setting:/usr/local/nagioslogserver/elasticsearch/config/elasticsearch.yml
Uncomment the line and change it to 500:# http.max_content_length: 100mb
Save the file and run the following commands:http.max_content_length: 500mb
service elasticsearch restart
service logstash restart
service httpd restart
I just configured as you suggested and now the error has been cleared. But after some time, I can see log receiving getting slower and free memory in nls instances are very low. sometimes 500 - 200mb.
swap also used.
Can you please help me to fix this? should I need to increase physical memory?
Currently, each nls having 32 GB RAM.
Regards
Luke.
swap also used.
Regards
Luke.
npolovenko
- Support Tech
@lukedevon, Yes, I suggest going up to 64Gb of ram if possible.
