Where's the NagiosXI DB locate?
Is there possible to connect to NagiosXI DB and collect or get some value?
Where's NagiosXI DB locate? can it be connected and collect?
npolovenko
- Support Tech
Re: Where's NagiosXI DB locate? can it be connected and coll
Hello, @xpertech. Sure, you can connect to the nagiosxi database in mysql:
I suggest creating a backup of NagiosXI before you do anything with the database.
mysql -u root -pnagiosxi nagiosxi
But be careful because one wrong command can damage the DB and make Nagios unrecoverable.mysql -u root -pnagiosxi nagiosql
