Bandwith Graphs show 0/0 in all network hosts.
I've added some hosts, using Wizard "Network Switch / Router" on NAgios XI, version 2.17.4.
Nagios language is Eng.
The ping and status graphs are working properly however the bandwith graphics do not. They always display values 0/0.
Can you help me please?
Thank you.
Thank you.
bolson
Re: Bandwith Graphs show 0/0 in all network hosts.
Hello psasines,
The version number you have given does not seem to be correct. If you're running version 5.5.7 or 5.5.8. Running the following commands from terminal of your Nagios XI host will resolve your issue:
Let us know if this resolves your issue. Thank you!
chown "apache:nagios" /etc/mrtg -R
chmod 775 /etc/mrtg -R
chown "apache:nagios" /var/lib/mrtg -R
chmod 775 /var/lib/mrtg -RRe: Bandwith Graphs show 0/0 in all network hosts.
Thank you for your reply.
After run the commands, the HP equipments(SNMP V2) start showing infomation, but de Cisco Equipments do not(SNMP V3).
Can you help?
Thank you
Can you help?
Thank you
bolson
Hello psasines,
Does the Cisco equipment send any information at all to your Nagios Server? If so, can you tell me what data is being returned and what data isn not? Thank you.
At this moment in cisco equipments the ping and status graphs are working properly however the bandwith graphics do not.
Thank you.
Thank you.
Please follow this guide for debugging:
Please PM one of us a copy of your profile as well and let us know the name of the Host you are having issues with so that we can look at your logs/configs. You can download your profile from Admin > System Profile, then click the Download Profile button.
Thank you
https://support.nagios.com/kb/article/nagios-xi-debugging-bandwidth-performance-graphs-29.htmlThank you
Hi
After doing the troubleshooting I get the expected values, except for the errors that I send in the attachment (File Errors).
The other attachment is what you asked for.
I have this problem on all cisco equipment, eg:
SCT-DWIFI02-DC01
SCT-VMWARE-DC02
SCT-BACKUPIT-DC01
SCT-DLANIT-DC01
Thank you
SCT-DWIFI02-DC01
SCT-VMWARE-DC02
SCT-BACKUPIT-DC01
SCT-DLANIT-DC01
Thank you
Please run this command and send me the entire output:
Additionally, please run the commands from the PM I sent you and let me know the results.
time LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgRe: Bandwith Graphs show 0/0 in all network hosts.
[root@localhost ~]# time LANC=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
ERROR: Mrtg will most likely not work properly when the environment
variable LANG is set to UTF-8. Please run mrtg in an environment
where this is not the case. Try the following command to start:
env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
real 0m0.008s
user 0m0.002s
sys 0m0.005s
real 0m0.008s
user 0m0.002s
sys 0m0.005s
You had a typo in the command, you put in LANC in place of LANG.
Can you run the following commands as root and post the the /tmp/mrtg.txt file here?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg -debug=cfg,base,log &> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg &>> /tmp/mrtg.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
