Monitoring application in Azure cloud which is paas
mohan23
Post by mohan23 »
I want to monitor application hosted as PAAS(platform as a service) in Azure cloud in nagios xi. Is there any way to get this done in nagios xi.
Regards,
Mohan Gandhi
benjaminsmith
Re: Monitoring application in Azure cloud which is paas
Post by benjaminsmith »
Hi @mohan23,
I would start with the Microsoft Azure Configuration Wizard in Nagios XI which utilizes the Nagios Cross Platform Agent (NCPA):
NCPA:
https://www.nagios.org/ncpa/
NCPA Installation Instructions
https://assets.nagios.com/downloads/ncp ... g-NCPA.pdf
Let me know if you need any other assistance.
mohan23
Post by mohan23 »
I want to do application level monitoring which is in Azure cloud. can we do this using ncpa agent? and How ?. If not do we have any other possibilities that we can do application level monitoring for an application which is in Azure cloud?
benjaminsmith
Hi @mohan23,
NCPA is our open source cross platform agent and can check variety of metrics such as memory, disk, processes,services ..etc.
A few useful links:
How To Monitor Devices Using The NCPA Agent and Wizard
We have a check library on our knowledge-base with configuration examples:
https://support.nagios.com/kb/category.php?id=186
And more technical documentation for NCPA can be found here:
https://www.nagios.org/ncpa/help.php#api-modules-system
Let me know if you have any specific questions.
