Hi Guys,
I have a service set up to warn me critical when reach 95% and warning 85%. But sometimes when the service reach 57% I already receive a critical message. This may be a Nagios bug?
The service is a Check_Oracle_DOCPE_Tablespace DOCPE_IDX
Threshold Warning and Critical - Wrong Information
bolson
Re: Threshold Warning and Critical - Wrong Information
Hello rpatricio,
So that we may be better equipped to diagnose your issue, please include the command definition (plugin) along with the argument list. And if possible, run the command in a terminal and post the results. Thank you.
Hi Bolson,
follow the output on command line and script attached.
[root@SPE001001-450 libexec]# ./check_tablespace_everis.sh DOCPE MAPESPVE caracas DOCPE_IDX 85 89 600
OK - tbs DOCPE_IDX usage is 58.05% |tbsDOCPE_IDX_usage_pct=58.05%;90;98 tbsDOCPE_IDX_usage=17832MB;27648;30105;0;30720 tbsDOCPE_IDX_alloc=30720MB;;;0;3072
bolson
Hello rpatricio,
Run the plugin again from the command line and immediately thereafter, type $? and press enter and tell me what the output is. If the output is 2, then the code in the plugin is flawed and is returning an incorrect exit code.
