php4nagios doesn't work on fresh install
davide.bonicelli
hi, i've just tried to install php4nagios on a new nagios installation on a centos 7 x64.
i followed the official guide
https://support.nagios.com/kb/article/n ... nd_Config)
but i stuck at the check of the page http://nagios_server/pnp4nagios/ that resolv in a not found page (of course i changed nagios_server with the correct ip)
any idea on this?
i don't see nothing in logs...
any idea on this?
Re: php4nagios doesn't work on fresh install
Go to the /var/log/httpd folder and look at the error_log file or if you enabled SSL the ssl_error_log file while you are trying to access the pnp4nagios link.
If you find any errors, post them here.
Can you get the Apache config file for PNP4Nagios and post it here?
/etc/httpd/conf.d/pnp4nagios.confBe sure to check out our Knowledgebase for helpful articles and solutions!
davide.bonicelli
Hi Tom, in i see only this in the error_log when i try to reach the webpage:
172.16.17.82 - - [27/Dec/2018:13:33:33 +0100] "GET /php4nagios HTTP/1.1" 404 208 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; Trident/7.0; rv:11.0) like Gecko"
the conf is this:
the conf is this:
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
Alias /pnp4nagios "/usr/local/pnp4nagios/share"
<Directory "/usr/local/pnp4nagios/share">
AllowOverride None
Order allow,deny
Allow from all
# Use the same value as defined in nagios.conf
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
<IfModule mod_rewrite.c>
# Turn on URL rewriting
RewriteEngine On
Options symLinksIfOwnerMatch
# Installation directory
RewriteBase /pnp4nagios/
# Protect application and system files from being viewed
RewriteRule "^(?:application|modules|system)/" - [F]
# Allow any files or directories that exist to be displayed directly
RewriteCond "%{REQUEST_FILENAME}" !-f
RewriteCond "%{REQUEST_FILENAME}" !-d
# Rewrite all other URLs to index.php/URL
RewriteRule "^.*$" "index.php/$0" [PT]
</IfModule>
</Directory>
The config file looks stock but thanks for posting it.
Here is a couple of things to look for.
When you access the pnp4nagios URL, it is accessing the following folder.
Check it to see if the permissions are set so the nagios user and and the nagcmd group can read it.
When you go to the GUI, does it prompt for a username and password?
If not, check the /usr/local/nagios/etc/htpasswd.users file to see if there is an account created in it.
Also, there are some steps you can do to troubleshoot this on the PNP4Nagios web site.
https://docs.pnp4nagios.org/pnp-0.6/verify
/usr/local/pnp4nagios/shareIf not, check the /usr/local/nagios/etc/htpasswd.users file to see if there is an account created in it.
davide.bonicelli
Thanks Tom, the permissions look good for me..
No user and pw asked when i go to the gui homepage..only 404
in htpasswd i see only nagiosadmin..is it correct?
in the link you send me i didn't found anything useful for my problem..
ls -la /usr/local/pnp4nagios/share
totale 20
drwxr-xr-x 8 nagios nagios 155 21 dic 11.22 .
drwxr-xr-x 9 root root 89 21 dic 11.06 ..
drwxr-xr-x 12 nagios nagios 144 21 dic 11.06 application
drwxr-xr-x 6 nagios nagios 60 21 dic 11.06 documents
-rw-r--r-- 1 nagios nagios 4785 21 dic 11.22 index.php
-rw-r--r-- 1 nagios nagios 7310 21 dic 11.22 install.php
drwxr-xr-x 5 nagios nagios 41 21 dic 11.06 media
drwxr-xr-x 2 nagios nagios 6 21 dic 11.06 templates
drwxr-xr-x 2 nagios nagios 4096 21 dic 11.22 templates.dist
drwxr-xr-x 2 nagios nagios 100 21 dic 11.22 templates.specialin htpasswd i see only nagiosadmin..is it correct?
If you did not add any other users to the htpasswd file, then the nagiosadmin user should be in there.
Lets try and reinstall pnp4nagios but specify the user and group in the configure command.
Go to the folder that you downloaded pnp4nagios and run the following commands as root to reinstall it.
Then see if you can login.
If it fails, try stopping the firewall of the system if it is enabled.
Try running the install script to see if that opens in the browser.
Other than that, there has to be more information in the Apache Error logs on why it is not running.
./configure --with-nagios-user=nagios --with-nagios-group=nagios
make all
make install
make install-webconf
make install-config
make install-init
service httpd restartIf it fails, try stopping the firewall of the system if it is enabled.
http://nagios_server/pnp4nagios/install.phpBe sure to check out our Knowledgebase for helpful articles and solutions!
davide.bonicelli
Thanks Tom, as usually you solved my problem : )
the
did the trick
the
configure --with-nagios-user=nagios --with-nagios-group=nagiosRe: php4nagios doesn't work on fresh install
Your Welcome. Glad it worked.
