Admin > Manage Users > Last Login time not updating
SteveBeauchemin
In Admin menu, Manage Users.
I have noticed on a new clean setup where I have made 2 users that the login time is not updating.
The user is setup as an Active Directory Auth Type. The Last Login column is not updating when I login / logout.
The Nagios XI version was a 5.5.7 install, just now upgraded to 5.5.8
The information does not update for either version.
Suggestions?
Steve B
Suggestions?
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Admin > Manage Users > Last Login time not updating
Steve, I noticed that when you masquerade as a user, the "Last Login" time doesn't get updated, however if you actually log in as this user, the "Last Login" time gets updated. At least this is what I am seeing on my test XI box. Can you confirm this?
SteveBeauchemin
Have not used Masquerade on these new systems yet. I have not notice that nor looked for it previously.
I came to my attention now as I only have 2 users defined.
I will look and test again after our holiday break. Will be gone for 2 weeks.
Steve B
Steve B
We are looking forward to your feedback. Meanwhile, we will do some more testing in house. Happy holidays!I will look and test again after our holiday break. Will be gone for 2 weeks.
SteveBeauchemin
I just logged in to a new server. Checked for the time stamp. Nothing...
So what next?
Steve B
So what next?
Steve B
npolovenko
- Support Tech
@SteveBeauchemin, I tried experimenting with LDAP/Active Directory users in the lab and the Last Login timestamp was correctly updating. Please sign in to XI a couple times with an LDAP user and then send in your system profile so that I can review it.
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and send it in a private message.
SteveBeauchemin
I just did a quick test and had no login information. But...
We use the DUO 2FA. I turned that off and did a logout and login and the time stamp updated.
I will send profile shortly.
Steve B
Steve B
I think you found a bug. Can you update the duo component to the attached to verify that the last login updates correctly.
SteveBeauchemin
Scott,
You nailed it. That worked.
Steve B
Steve B
Awesome. Thanks for testing. We are releasing this update as an updated component tonight.SteveBeauchemin wrote:Scott,
Steve B
Locking thread
