Failure Predicted
chris1337c
Failure Predicted
Post by chris1337c »
Hi there,
I am trying to identify the best solution for having NAGIOSCore 4 detect the health on the HD's on 3 different hypervisors. I am running into trouble because these are Dell PowerEdge servers, when I login to the Server Manager it will list Failure Predicted: Yes on hard drives that need to be replaced. But Nagios Core is reporting the Global Health as *green* / or healthy as it will not report until they fail.
Has anyone encountered this? What are the best ways I could accomplish this?
Appreciate any help or support as I am new to Nagios!
Chris
chris1337c
Re: Failure Predicted
https://exchange.nagios.org/directory/P ... ay/details
I found this, I suspect this will be the winner but I am not positive.
cdienger
Post by cdienger »
A little trial an error may be necessary to find out what plugin will work best. Which one are you using now?
The link you provided may work and would be easy enough to test. Just download the script onto the Nagios machine, make it executable, and run it.
Perl PERC disk array plugin for Nagios
Usage:
  check_perc.pl [options] <hostname>
  Options:
    -C snmp-community
    -p snmp-port
    --debug
There are other plugins and even an official one from Dell if this one doesn't do the trick.
chris1337c
We have the Open_manage plugin currently installed. I have been reading on how to configure it to do this here:
http://folk.uio.no/trondham/software/ch ... ation-file
cdienger
Post by cdienger »
There's also a Dell forum for this plugin: https://www.dell.com/community/OpenMana ... 3rd-Party-
chris1337c
I posted this in the Dell Forums, thank you for the tip! :D
cdienger
Post by cdienger »
No problem!
chris1337c
chris1337c wrote:https://www.dell.com/community/OpenMana ... 1777#M1500
Posted here, no response yet.
Looks like they responded today
chris1337c
:D :D :D :D :D :D :D :D :D :D
