Unable to apply configuration
smapple
Post by smapple »
Hello Team,
PLease see the attached file. I am unable to apply configuration due to an user settings( NO more used).Can you please let me know what how to get rid of user?
Thanks!
npolovenko
Re: Unable to apply configuration
Post by npolovenko »
Hello, @smapple. Please go to Configure -> Core Configurations Manager in XI. Then in the left column click on Contacts. Do you see a contact named "ehanda"? If you do please delete and then apply configuration one more time.
smapple
Post by smapple »
I have already deleted the contacts. And the user in Admin > users.
However still see the same issue
smapple
Post by smapple »
Hello, Can you please check on this?
smapple
Post by smapple »
Hello team,
Sorry to ask this. I hope you are seeing my messages?
smapple
Post by smapple »
Restarted the nagios services. However no luck.Same issues.Can you have a look?
npolovenko
@smapple, Yes, I can see your messages at 12:35 pm and 1:05 pm. Currently, we're answering forum posts in the order we receive them. Our SLA guarantees that we provide a response within 24 hours(during non-holidays).
Please run the repair databases script as root:
/usr/local/nagiosxi/scripts/repair_databases.sh
Next, in XI web interface please go to Configure -> Core Configurations Manager, then click on Tools -> Config File Management in the left column. Then perform the following actions in order:
1)Write
2)Delete
3)Write
4)Verify
After you click on the verify you will see some errors in the GUI. Please copy and paste them in this thread.
smapple
Post by smapple »
This is the messages from verify. Also I tried to do the Apply COnfigurations its still the same.
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Warning: Service 'Ping' on host 'bsolutions2-fm12.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X AFP Connections' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X AFP Status' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X CPU' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X Diskspace All Volumes' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X Memory' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X Netvault Status' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X SMART Status' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'OS X Uptime' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Warning: Service 'Ping' on host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Checked 1277 services.
Warning: Host '17.208.82.197' has no default contacts or contactgroups defined!
Warning: Host 'awreport-db.apple.com' has no default contacts or contactgroups defined!
Warning: Host 'bsolutions2-fm12.apple.com' has no default contacts or contactgroups defined!
Warning: Host 'fg1-fs02.apple.com' has no default contacts or contactgroups defined!
Checked 186 hosts.
Checked 25 host groups.
Checked 0 service groups.
Warning: Host recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify down and/or unreachable options as well
Warning: Service recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify critical and/or warning options as well
Checked 6 contacts.
Checked 6 contact groups.
Checked 132 commands.
Checked 12 time periods.
Checked 0 host escalations.
Checked 186 hosts
Checked 0 host dependencies
Checked 12 timeperiods
Checking misc settings...
Total Warnings: 16
Total Errors: 0
npolovenko
@smapple, Could you PM me a copy of your system profile?
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and send it to me in a private message.
After you send the profile please post something in this thread to bring it back up in the support queue.
smapple
Post by smapple »
I have sent the profile.zip in a private message to you.
