Scheduled Backups
CJIndustries
Scheduled Backups
Post by CJIndustries »
I noticed that once I upgraded to 5.5.8, the scheduled SSH backups are not working. Please advise. Thank you.
ssax
Dreams In Code
Re: Scheduled Backups
Post by ssax »
The first thing to check is for disk space issues, please send the output of these commands:
df -h
df -i
Then see if you have any crashed tables, post the output of this command:
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -uroot -pnagiosxi --table
Then check the contents of this file to see if you see any errors:
/usr/local/nagiosxi/var/components/scheduledbackups.log
Finally, do regular local backups work properly? Please login as root an run these commands and post the full output if it fails:
./backup_xi.sh
Additionally, please post a screenshot of your Scheduled backup SSH settings from Admin > Scheduled Backups.
What is the output of this command as well:
ls -l /store/backups/nagiosxi
CJIndustries
Attached output of requested commands.
ssax
Dreams In Code
Post by ssax »
You have a crashed DB table, that's likely why it's failing:
| nagios_commenthistory                      |       NULL |
mysqldump: Got error: 144: Table './nagios/nagios_commenthistory' is marked as crashed and last (automatic?) repair failed when using LOCK TABLES
Please follow this guide to repair your DB tables:
https://support.nagios.com/kb/article/n ... es-24.html
Then try the backup again and it'll likely work.
CJIndustries
Tested both local and scheduled. Looks like they are working fine now. Thanks.
npolovenko
Post by npolovenko »
@CJIndustries, I will be closing this thread as resolved. However, feel free to open a new one if something else comes up.
