Nagios checking Exchange URL (login required)
Hello All,
I have somewhat of an odd request. To begin we are running Nagios XI 5.5.7 and NSClient++ 5.3.
On our Exchange frontend servers I need to monitor this address https://SERVER/ews/exchange.asmx/wssecurity. Browsing to this address prompts for a login and brings you to a XML page. When that happens all is working. If the XWL page does not load I need to restart the MSExchangeServicesAppPool.
So I need a script/plugin that points to that address, inputs logins info and check XML page.
I apologize for the odd request but any help on talking this will be greatly appreciated.
Thank you
Ryan
Thank you
Ryan
Re: Nagios checking Exchange URL (login required)
A very important question; How is it prompting for a login? Is it using basic authentication? Some sort of form based authentication?RyanMule wrote:this address prompts for a login
The check_http plugin supports basic authentication via the -a argument:
-a, --authorization=AUTH_PAIR
Username:password on sites with basic authentication
-e, --expect=STRING
Comma-delimited list of strings, at least one of them is expected in
the first (status) line of the server response (default: HTTP/1.)
If specified skips all other status line logic (ex: 3xx, 4xx, 5xx processing)
-d, --header-string=STRING
String to expect in the response headers
-s, --string=STRING
String to expect in the content
-l, --linespan
Allow regex to span newlines (must precede -r or -R)
-r, --regex, --ereg=STRING
Search page for regex STRING
-R, --eregi=STRING
Search page for case-insensitive regex STRING
--invert-regex
Return CRITICAL if found, OK if notIf you're having to navigate forms-based authentication, I'd recommend the following documentation (specifically the bit about the "web transaction" wizard):
Doesn't strike me as oddRyanMule wrote: I apologize for the odd request
Hello Mcapra,
Thank you for the quick response!
Yes... I missed that key part... It is form based authentication, so it does complicate it a bit.
I am not looking for anything specific in the XML document just as long as is generated.
This is all great information! I have some work to do and I will provide an update asap
Thank you!
Thank you!
mcapra wrote:A very important question; How is it prompting for a login? Is it using basic authentication? Some sort of form based authentication?RyanMule wrote:this address prompts for a login
The check_http plugin supports basic authentication via the -a argument:In terms of answering the "did the XML page generate" question, hoo boy there's a lot of options starting with checking response codes (200, 400, 503, etc)Code: Select all
-a, --authorization=AUTH_PAIR Username:password on sites with basic authenticationChecking response headers (Content-Type, XSS, etc):Code: Select all
-e, --expect=STRING Comma-delimited list of strings, at least one of them is expected in the first (status) line of the server response (default: HTTP/1.) If specified skips all other status line logic (ex: 3xx, 4xx, 5xx processing)Checking body contents (specific XML key/value pairs maybe?):Code: Select all
-d, --header-string=STRING String to expect in the response headersReally depends on the specific site, but check_http can cover an awful lot of ground by itself assuming basic auth is the authentication mechanism.Code: Select all
-s, --string=STRING String to expect in the content ... -l, --linespan Allow regex to span newlines (must precede -r or -R) -r, --regex, --ereg=STRING Search page for regex STRING -R, --eregi=STRING Search page for case-insensitive regex STRING --invert-regex Return CRITICAL if found, OK if not
Doesn't strike me as oddRyanMule wrote: I apologize for the odd requestLogin checks are super handy for multiple reasons.
If it is using form based authentication you will need to use the check_http -P option:
You will need to URL encode the data:
https://www.urlencoder.org/
You will need to work with your application developers to determine what POST data you need to submit such as username/pass/etc.
Something like this may work:
-P, --post=STRING
URL encoded http POST datahttps://www.urlencoder.org/
/usr/local/nagios/libexec/check_http -H SERVER -f follow -u '/ews/exchange.asmx/wssecurity' --method=POST -P 'username=USER&password=PASS&loginButton=' -s 'TEXT TO SEARCH FOR' -S -p 443 --sni-
optionstechnology
FYI: I came across a very similar issue and resolved by monitoring the IIS AppPool itself with check_iis -
https://exchange.nagios.org/directory/P ... ol/details
Glad to hear you found another plugin that seems to work. Are we good to lock this one up?
Thank you ssax!
I will look into this option as well.
ssax wrote:If it is using form based authentication you will need to use the check_http -P option:
You will need to URL encode the data:Code: Select all
-P, --post=STRING URL encoded http POST data
Yes, this can be locked for now.
cdienger wrote:Glad to hear you found another plugin that seems to work. Are we good to lock this one up?
LockingRyanMule wrote:Yes, this can be locked for now.
