Critical alert issue
manimurugesan
Hello Team,
We are monitoring "as400" servers but In older version i.e. Nagios XI 5.4.12 all the services working fine . but recently we have upgraded the server to Nagios XI 5.5.5 after that services started showing critical alert
In both the servers we are monitoring through check_as400 plugin but In new version only it's showing alert
Please find the below alert which is showing in nagiosxi
CRITICAL: Network error:javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable
Could you please help us to resolve this issue ?
Last edited by manimurugesan on Fri Jan 25, 2019 12:46 pm, edited 1 time in total.
npolovenko
- Support Tech
Re: After upgrdation Critical alert issue
@manimurugesan, This looks like a certificate issue. Make sure you do this:
https://exchange.nagios.org/directory/P ... 00/detailsInstall Note
Must add CE to JAVA, EX:
keytool -import -trustcacerts -keystore /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.85.x86_64/jre/lib/security/cacerts -storepass changeit -noprompt -alias xxxx_ce -file /xx/xxx/XXXX.cer
manimurugesan
Hello npolovenko,
Can you please share me the procedure to install the certificate ?
npolovenko
- Support Tech
@manimurugesan, First, let's check the permissions on the plugin:
It looks like reinstalling the plugin should take care of certificates. I suggest downloading the latest version of the check_as400 plugin from https://exchange.nagios.org/directory/P ... 00/details and reinstalling it on the server. The installation instruction is in the ReadMe file inside the archive.ls -l /usr/local/nagios/libexec/check_as400*
manimurugesan
Hello ,
I have installed new plugin
while installing new plugin I am not able to give the /usr/local/nagios/libexec folder, I given the default folder which showing in automatically
But still issue not resolved .
Could you please clarify this ?
npolovenko
- Support Tech
@manimurugesan, /usr/local/nagios/libexec is the default folder. I downloaded the latest version of the plugin from the github page:
https://github.com/cjt74392/check_as400
Followed the installation entering paths to my nagios.cfg file and to the java binary.
I can run the plugin with no errors.
My further recommendation is to either reinstall the Java on your server or open an issue on the plugin authors git hub page:
https://github.com/cjt74392/check_as400/issues/new
With that said, I don't have an as400 server in the lab so I can't run any commands and fully test the functionality.[root@centos7x64 libexec]# ./check_as400 -V
Check_as400 Version: 1.4.6
npolovenko
- Support Tech
manimurugesan
Hello ,
We have tried but issue is still persist
Please let me know to resolve this issue can we get remote session?
What do you mean by this?manimurugesan wrote:Hello ,
Did you follow this guide for adding plugins to Nagios XI?
If so it will automatically be placed in /usr/local/nagios/libexec which is the default folder
I don't know anything of as400, but did you try running the plugin with debug switch?
In https://github.com/cjt74392/check_as400 ... as400.java :
Grtz
Willem
System.out.println("-d\n Be verbose (debug)\n NOTE: Needs to be one of the first arguments to work");Willem
Nagios XI 5.8.1
https://outsideit.net
