Process fills up all available space
vmesquita
Post by vmesquita »
We are having an issue in which some process in the Nagios server fills up all the free space (13Gb), up to the point where some functions like login on the web interface doesn't work anymore. Then after a while this space is released again. We have the /store folder in a separated partition so we know that it's not what's taking up space. Would you have any ideas on how to investigate this?
Re: Process fills up all available space
Can you run the following commands as root when the system's drive fills up and post the output here?
df -h
df -i
ps -ef --cols=300
Find largest 10 directories by size command:
find / -type d -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
Find the largest 10 files by size command:
find / -type f -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
Can you run them now as well and post it here so we can see that the server current drive allocations and file usage it has now?
vmesquita
Post by vmesquita »
Hi tgriep, thanks for the reply.
I tried to run the recommended commands, however it also gets the mount points we have at /var (like /var/sa530,/var/sb530 etc). So the between the 10 biggest folders those mount points were taking in account which probably doesn't make much sense. Is there a way to exclude some folders in the command?
The simplest thing to do is to just run the command against the partition that files up.
For example, if the /var partition fills up, run the command like so.
find /var -type f -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
Or, to exclude the /var folder, run this
find / -path '/var' -prune -o -type f -print0 ! -path "/var/*" | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
