Since the last Update version of Nagios XI 2011R2.2 I am getting the following message when running the upgrade script. Though everything seems fine since Nagios XI runs smootly after the upgrade and also shows the new version. Still, I had expected from the past that the upgrade script would respond with "complete". Can you please check.
[root@h1997468 nagiosxi]# ./upgrade
Patching NDOUtils...
NDOUtils already patched at level 102
Yum not configured - skipping prereqs update
Copying over new XI directory...
/bin/chown: Zugriff auf â/usr/local/nagiosxi/tmp/*.zipâ nicht möglich: Datei oder Verzeichnis nicht gefunden
Upgrade Issue
Re: Upgrade Issue
Please see this post for a quick fix
http://support.nagios.com/forum/viewtop ... 163#p22647
Re: Upgrade Issue
Sorry to come back so late with my response.
The workaround is fine.
Issues can be closed.
Many Tx!
Many Tx!
