DB.nagios alias is not DB.nagiosql's alias
yangzhiyao2653
Shown in nagiosql alias is Chinese simplified, but is shown in the nagios gibberish, who has encountered this problem, please?
Re: DB.nagios alias is not DB.nagiosql's alias
What are the character settings on the databases when you run:
SELECT default_character_set_name FROM information_schema.SCHEMATA S WHERE schema_name = "nagios";
SELECT default_character_set_name FROM information_schema.SCHEMATA S WHERE schema_name = "nagiosql";
yangzhiyao2653
Both is latin1.
I try to change the default character set and character collation but for the former data I want to know how to change?
npolovenko
- Support Tech
@yangzhiyao2653, Consider changing the default character set to UTF-8. Let me know if the solution here works for you:
https://stackoverflow.com/questions/351 ... -in-my-cnf
Before you do anything please backup Nagios:
yangzhiyao2653
I've put the nagios server, database, table, column configuration as utf8, then restart the database service and apply nagios CCM, found the database is shown as utf8.But instead of on the page with the unreadable code, in the home page and report, do you know about this situation?
Please go to Configure > Core Config Manager > Hosts:
- Edit VLXCNDSZ01BPMP1 through 9 and change the Alias to what it should be, Save, then apply configuration and see if it's proper now.
This is likely a result of the conversion to utf-8.
Let us know the results.
yangzhiyao2653
Is still can't display properly, I will want to is a question of PHP, but I for PHP is not understand, may need your help
Are the databases showing correct characters now if you run initial query again?
Edit /etc/httpd/conf/httpd.conf and make sure the following is in there:
AddDefaultCharset utf-8
Also, check /etc/php.ini and uncomment this like:
;default_charset = "UTF-8"
Restart the apache service after making any changes to these files:
service httpd restart
yangzhiyao2653
It still can't display properly,I will take a ticket with it .if you have any idea ,please tell me, thank you.
I see a ticket has been opened. We'll continue troubleshooting though there.
