Uninstalling Nagiosxi Agent?
Is there a way to uninstall the nagiosxi agent cleanly? I need to be running the RPM for NRPE and not an agent that is compiling code.
Re: Uninstalling Nagiosxi Agent?
Which agent did you install? That you want to remove? ie. what type of machine do you have this installed on?
We figured it out. Sadly due to the agent being compiled and not an RPM, we cant use it in our production environment.
Is there an RPM for the NagiosXI agent?
We don't have an "official" rpm for NRPE, but you can check out this link:
http://pkgs.repoforge.org/nagios-nrpe/
You will have to deal with dependencies, setting up firewall rules, etc.
You can also try yum. In this case, you won't have to deal with dependencies - yum should take care of them.
Hope this helps.
# yum list available nrpeBe sure to check out our Knowledgebase for helpful articles and solutions!
