Nrpe Installation on RHEL 6
Johnsmit
Post by Johnsmit »
we have a few RHEL 6 servers, we would like to monitor them using NagiosXI. i tried to look for document on OFFLINE installation of NRPE on RHEL 6 . All i found is a common document for both RHEL 7 and RHEL 6. so is it the same doc for both versions? if not please provide me the correct source for installation of NRPE on RHEL 6.
ssax
Dreams In Code
Re: Nrpe Installation on RHEL 6
Post by ssax »
Please link us to the doc you found, I don't think we have an official offline NRPE Agent installer and I want to validate what it says.
Generally, as long as the prerequisites are installed, it should compile just fine:
https://support.nagios.com/kb/article.php?id=515#RHEL
Are you trying to compile from source or use the Linux NRPE Agent installer?
