Nagios 'check_http' plugin '--no-body' question
espressobeanies
Post by espressobeanies »
Just had a question about the Nagios 'check_http --no-body' option: Is it just limited to HTTP headers or does this include HTML tags like the <title> of a webpage?
Re: Nagios 'check_http' plugin '--no-body' question
It is it just limited to HTTP headers
espressobeanies
Scott, thanks for the reply. The reason I'm asking this is that I have Nagios checking the uptime status of a 404 error page and with the existence of the '--no-body' option, I'm still seeing the HTTP/1.1 response display a "404 Not Found" message even though it should just be checking the HTTP headers only.
ssax
Dreams In Code
Post by ssax »
Please try using the -j HEAD option instead of --no-body:
 -j, --method=STRING  (for example: HEAD, OPTIONS, TRACE, PUT, DELETE, CONNECT)
    Set HTTP method.
 -N, --no-body
    Don't wait for document body: stop reading after headers.
    (Note that this still does an HTTP GET or POST, not a HEAD.)
