Hello XI support,
We installed XI with https enabled at first time.
But our client ask us to disable https; they want to connect through http only.
And I tried to find some settings on XI Web UI, like "/Admin/System settings", found nothing relative.
Is there any way to disable https on UI?
OR, we need to modify some config file such as "config.inc.php" or "ssl.conf" to achieve this?
Thanks!
System Info:
- CentOS 7, 64 bit
- VM
- pure Nagios XI installed, no other apps (even nginx)
How to Disable HTTPS on XI?
benjaminsmith
Re: How to Disable HTTPS on XI?
Hello @axvers,
By default, Nagios XI doesn't force the use of SSL. Go to Admin > System Settings > General Program Settings and make sure the Program URL is not set for https.
Also, there is a configuration setting for force https in /usr/local/nagiosxi/html/config.inc.php. Make sure that is set to false.
Let me know if you have any other questions. Thanks.
// Force http/https
$cfg['use_https'] = false; // determines whether cron jobs and other scripts will force the use of HTTPS instead of HTTP
It turned out that these settings are not working.
The XI site still auto-connect over https (image 002).
We changed the Admin > System Settings > General Program Settings (image 001)
and
/usr/local/nagiosxi/html/config.inc.php. (image 004)
, then restart httpd.
Is there any other settings need to be modified?
Thanks!
and
Thanks!
In addition to what you already did, do the following:
1. Open the /etc/httpd/conf.d/ssl.conf file in a text editor, and change these two lines:
to these:
Go to the bottom of the file, and remove (or comment out) this section:
Save and exit.
2. Open the /etc/httpd/conf.d/nagiosxi.conf file in a text editor, and change this:
to this:
Save and exit.
3. Restart apache:
Let us know if this helped. Thank you!
SSLCertificateFile /usr/local/nagiosxi/var/certs/nagiosxi.crt
SSLCertificateKeyFile /usr/local/nagiosxi/var/certs/nagiosxi.keyCode: Select all
SSLCertificateFile /etc/pki/tls/certs/localhost.crt
SSLCertificateKeyFile /etc/pki/tls/private/localhost.keyCode: Select all
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>2. Open the /etc/httpd/conf.d/nagiosxi.conf file in a text editor, and change this:
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
</IfModule>Code: Select all
RewriteEngine On
</IfModule>3. Restart apache:
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi Support,
It worked like a charm!
Thank you very much!
I am glad I could help!
