NSClien++ password
techieepro
NSClien++ password
Post by techieepro »
Hi ,
I'm new bee to Nagios Core. I have setup of nagios core. Have installed nsclient++ in windows client, but when checked in nagios it is showing unable to connect to client. Anybody help me that which password i have to enter in nsclient++ (windows) while installing.
Naresh
Re: NSClien++ password
Post by mcapra »
There's nothing wrong with NSClient++, but NCPA is what is now officially recommended for performing Windows checks:
https://assets.nagios.com/downloads/nag ... ndows.html
This documentation references Nagios XI, but the parts that cover setting up NSClient++ are still relevant:
On page 3, you configure a password for use with check_nt via the installation wizard. That password can be whatever you want, and you can change it at any time in the nsclient.ini configuration file.
Let us know if you have additional questions, or if something is unclear :)
You should also be able to see the password in the C:\Program Files\NSClient++\nsclient.ini file.
