I followed the instructions for creating a ramdisk on your site (https://assets.nagios.com/downloads/nag ... giosXI.pdf) and all worked well.
However, every time I upgrade, I have to re-check the config files as you haven't specified some of the files which were changed as config files in their rpm specs. For the 5.5.7 upgrade, /usr/local/nagios/etc/pnp/npcd.cfg (nagiosxi-pnp-5.5.7-1.el7.x86_64.rpm) and /usr/local/nagiosmobile/include.inc.php (nagiosxi-nagiosmobile-5.5.7-1.el7.x86_64.rpm) are overwritten. Could these be re-specified as config files in the spec?
Offline tarball config files overwritten
Re: Offline tarball config files overwritten
Yes! I have made the change and they will take affect for versions > 5.5.8dave_lux wrote:Could these be re-specified as config files in the spec?
Thanks very much for your amazingly really quick reaction!!!
Happy New Year!
Best regards,
Dave
Happy New Year!
Best regards,
Dave
No problem. Happy New Year to you!dave_lux wrote:Thanks very much for your amazingly really quick reaction!!!
Happy New Year!
Best regards,
Dave
Locking thread
