Monitor Amazon EC2 linux
Hi Team,
We are getting error while configure Nagios monitoring on our amazon linux machine. Below is the details which was we are followed.
1- cd /tmp
2- wget https://assets.nagios.com/downloads/nag ... ent.tar.gz
3- tar xzf linux-nrpe-agent.tar.gz
4- cd linux-nrpe-agent
5- ./fullinstall
Error- Amazon is not currently supported. Please use either Red Hat, CentOS, Oracle Linux, CloudLinux, SUSE Enterprise, OpenSUSE, Ubuntu, or Debian.
OS Details-
Amazon Linux release 2 (Karoo)
Please find out the attachment for more details.
Thanks.
1- cd /tmp
5- ./fullinstall
OS Details-
Thanks.
Re: Monitor Amazon EC2 linux
You are correct the current Linux Agent installer doesn't support Amazon linux.
You should be able to follow the CentOS guide for a manual install here
https://support.nagios.com/kb/article.php?id=515
Thanks Issue resolve now.
Could you send me the link for monitor cpu, memory. Also I have configured check_disk to monitor disks.But the issue is we are able to monitor only / not /use/local/share/mnt please find out attachment.
Yes. This is mount point. Please find out the attachment.
Hmm, does the nagios user have access to that mount point?
ls -dl /use/local/share/mnt
su nagios -c 'df -h'Re: Monitor Amazon EC2 linux
Yes Nagios user have access.
Actually the command you posted is a check_disk command on the local Nagios XI server, it isn't connecting via NRPE to the remote server
Oky. How i can resolve this, also please help in CPU and Memory monitoring.
Page 3 here covers how to add command directives to your nrpe.cfg
https://assets.nagios.com/downloads/nag ... g_NRPE.pdf
Something like this
then you can use the NRPE wizard to check for check_disk_share_mnt
Something like this
command[check_disk_share_mnt]=/usr/local/nagios/libexec/check_disk -c 85 -p /use/local/share/mnt
