Host check timed out check_snmp_synology
Hi there,
Im currently trying to setup a monitoring service on my Synology NAS but im facing some challenges.
As of today I have two Synology NAS'es in my setup and monitoring is working excellent on one of them (NAS01)
I'm utilizing the nagios plugin check_snmp_synology.
Error message emailed to me
***** Nagios *****
Notification Type: PROBLEM
Host: NAS02
State: DOWN
Address: <HOSTIP>
Info: (Host check timed out after 60.03 seconds)
Objects host/service
define host {
use synology-server
host_name NAS02
alias NAS02.mydomain.com
address <HOSTIP>
check_command check_snmp_synology
host_name NAS02
service_description Server infomation
Let me know if you need further information to analyze the issue.
EDIT:
Nagios is running on Ubuntu 14.04.4 LTS
***** Nagios *****
Host: NAS02
State: DOWN
Address: <HOSTIP>
define host {
use synology-server
host_name NAS02
address <HOSTIP>
host_name NAS02
EDIT:
Re: Host check timed out check_snmp_synology
Can you share the configuration for your command check_snmp_synology
Can you run the command from the command line successfully?
#!/bin/bash
# check_snmp_synology for nagios
# Version: 2.5
# 07.12.2016 Nicolas Ordonez, Switzerland
# Thanks to contributors:
# - Tobias Schenke
# this plugin checks the health of your Synology NAS
# - System status (Power, Fans)
# - Disks status
# - RAID status
# - DSM update status
# - Temperature Warning and Critical
# - UPS information
# - Storage percentage of use
# Tested with DSM 5.0, 5.1 & 6.0
# Based on http://ukdl.synology.com/download/Document/MIBGuide/Synology_DiskStation_MIB_Guide.pdf
# actual number disk limit = 52 disks per Synology
SNMPWALK=$(which snmpwalk)
SNMPGET=$(which snmpget)
SNMPVersion="3"
SNMPV2Community="mjgroup"
SNMPTimeout="10"
warningTemperature="60"
criticalTemperature="70"
warningStorage="80"
criticalStorage="95"
hostname=""
healthWarningStatus=0
healthCriticalStatus=0
healthString=""
verbose="no"
checkDSMUpdate="yes"
ups="no"
#OID declarations
OID_syno="1.3.6.1.4.1.6574"
OID_model="1.3.6.1.4.1.6574.1.5.1.0"
OID_serialNumber="1.3.6.1.4.1.6574.1.5.2.0"
OID_DSMVersion="1.3.6.1.4.1.6574.1.5.3.0"
OID_DSMUpgradeAvailable="1.3.6.1.4.1.6574.1.5.4.0"
OID_systemStatus="1.3.6.1.4.1.6574.1.1.0"
OID_temperature="1.3.6.1.4.1.6574.1.2.0"
OID_powerStatus="1.3.6.1.4.1.6574.1.3.0"
OID_systemFanStatus="1.3.6.1.4.1.6574.1.4.1.0"
OID_CPUFanStatus="1.3.6.1.4.1.6574.1.4.2.0"
OID_disk=""
OID_disk2=""
OID_diskID="1.3.6.1.4.1.6574.2.1.1.2"
OID_diskModel="1.3.6.1.4.1.6574.2.1.1.3"
OID_diskStatus="1.3.6.1.4.1.6574.2.1.1.5"
OID_diskTemp="1.3.6.1.4.1.6574.2.1.1.6"
OID_RAID=""
OID_RAIDName="1.3.6.1.4.1.6574.3.1.1.2"
OID_RAIDStatus="1.3.6.1.4.1.6574.3.1.1.3"
OID_Storage="1.3.6.1.2.1.25.2.3.1"
OID_StorageDesc="1.3.6.1.2.1.25.2.3.1.3"
OID_StorageAllocationUnits="1.3.6.1.2.1.25.2.3.1.4"
OID_StorageSize="1.3.6.1.2.1.25.2.3.1.5"
OID_StorageSizeUsed="1.3.6.1.2.1.25.2.3.1.6"
OID_UpsModel="1.3.6.1.4.1.6574.4.1.1.0"
OID_UpsSN="1.3.6.1.4.1.6574.4.1.3.0"
OID_UpsStatus="1.3.6.1.4.1.6574.4.2.1.0"
OID_UpsLoad="1.3.6.1.4.1.6574.4.2.12.1.0"
OID_UpsBatteryCharge="1.3.6.1.4.1.6574.4.3.1.1.0"
OID_UpsBatteryChargeWarning="1.3.6.1.4.1.6574.4.3.1.4.0"
usage()
echo "usage: ./check_snmp_synology [OPTIONS] -u [user] -p [pass] -h [hostname]"
echo "options:"
echo " -u [snmp username] Username for SNMPv3"
echo " -p [snmp password] Password for SNMPv3"
echo ""
echo " -2 [community name] Use SNMPv2 (no need user/password) & define community name (ex: public)"
echo ""
echo " -h [hostname or IP](:port) Hostname or IP. You can also define a different port"
echo ""
echo " -W [warning temp] Warning temperature (for disks & synology) (default $warningTemperature)"
echo " -C [critical temp] Critical temperature (for disks & synology) (default $criticalTemperature)"
echo ""
echo " -w [warning %] Warning storage usage percentage (default $warningStorage)"
echo " -c [critical %] Critical storage usage percentage (default $criticalStorage)"
echo ""
echo " -i Ignore DSM updates"
echo " -U Show informations about the connected UPS (only information, no control)"
echo " -v Verbose - print all informations about your Synology"
echo ""
echo ""
echo "examples: ./check_snmp_synology -u admin -p 1234 -h nas.intranet"
echo " ./check_snmp_synology -u admin -p 1234 -h nas.intranet -v"
echo " ./check_snmp_synology -2 public -h nas.intranet"
echo " ./check_snmp_synology -2 public -h nas.intranet:10161"
exit 3
if [ "$1" == "--help" ]; then
usage; exit 0
fi
while getopts 2:W:C:w:c:u:p:h:iUv OPTNAME; do
case "$OPTNAME" in
u) SNMPUser="$OPTARG";;
p) SNMPPassword="$OPTARG";;
h) hostname="$OPTARG";;
v) verbose="yes";;
2) SNMPVersion="2"
SNMPV2Community="$OPTARG";;
w) warningStorage="$OPTARG";;
c) criticalStorage="$OPTARG";;
W) warningTemperature="$OPTARG";;
C) criticalTemperature="$OPTARG";;
i) checkDSMUpdate="no";;
U) ups="yes";;
*) usage;;
esac
done
if [ "$warningTemperature" -gt "$criticalTemperature" ] ; then
echo "Critical temperature must be higher than warning temperature"
echo "Warning temperature: $warningTemperature"
echo "Critical temperature: $criticalTemperature"
echo ""
echo "For more information: ./${0##*/} --help"
exit 1
fi
if [ "$warningStorage" -gt "$criticalStorage" ] ; then
echo "The Critical storage usage percentage must be higher than the warning storage usage percentage"
echo "Warning: $warningStorage"
echo "Critical: $criticalStorage"
echo ""
exit 1
fi
if [ "$hostname" = "" ] || ([ "$SNMPVersion" = "3" ] && [ "$SNMPUser" = "" ]) || ([ "$SNMPVersion" = "3" ] && [ "$SNMPPassword" = "" ]) ; then
usage
else
if [ "$SNMPVersion" = "2" ] ; then
SNMPArgs=" -OQne -v 2c -c $SNMPV2Community -t $SNMPTimeout"
else
SNMPArgs=" -OQne -v 3 -u $SNMPUser -A $SNMPPassword -l authNoPriv -a MD5 -t $SNMPTimeout"
if [ ${#SNMPPassword} -lt "8" ] ; then
echo "snmpwalk: (The supplied password is too short.)"
exit 1
fi
fi
tmpRequest=`$SNMPWALK $SNMPArgs $hostname $OID_syno 2> /dev/null`
if [ "$?" != "0" ] ; then
echo "CRITICAL - Problem with SNMP request, check user/password/host"
exit 2
fi
nbDisk=$(echo "$tmpRequest" | grep $OID_diskID | wc -l)
nbRAID=$(echo "$tmpRequest" | grep $OID_RAIDName | wc -l)
for i in `seq 1 $nbDisk`;
do
if [ $i -lt 25 ] ; then
OID_disk="$OID_disk $OID_diskID.$(($i-1)) $OID_diskModel.$(($i-1)) $OID_diskStatus.$(($i-1)) $OID_diskTemp.$(($i-1)) "
else
OID_disk2="$OID_disk2 $OID_diskID.$(($i-1)) $OID_diskModel.$(($i-1)) $OID_diskStatus.$(($i-1)) $OID_diskTemp.$(($i-1)) "
fi
done
for i in `seq 1 $nbRAID`;
do
OID_RAID="$OID_RAID $OID_RAIDName.$(($i-1)) $OID_RAIDStatus.$(($i-1))"
done
if [ "$ups" = "yes" ] ; then
syno=`$SNMPGET $SNMPArgs $hostname $OID_model $OID_serialNumber $OID_DSMVersion $OID_systemStatus $OID_temperature $OID_powerStatus $OID_systemFanStatus $OID_CPUFanStatus $OID_disk $OID_RAID $OID_DSMUpgradeAvailable $OID_UpsModel $OID_UpsSN $OID_UpsStatus $OID_UpsLoad $OID_UpsBatteryCharge $OID_UpsBatteryChargeWarning 2> /dev/null`
else
syno=`$SNMPGET $SNMPArgs $hostname $OID_model $OID_serialNumber $OID_DSMVersion $OID_systemStatus $OID_temperature $OID_powerStatus $OID_systemFanStatus $OID_CPUFanStatus $OID_disk $OID_RAID $OID_DSMUpgradeAvailable 2> /dev/null`
fi
if [ "$OID_disk2" != "" ]; then
syno2=`$SNMPGET $SNMPArgs $hostname $OID_disk2 2> /dev/null`
syno=$(echo "$syno";echo "$syno2";)
fi
model=$(echo "$syno" | grep $OID_model | cut -d "=" -f2)
serialNumber=$(echo "$syno" | grep $OID_serialNumber | cut -d "=" -f2)
DSMVersion=$(echo "$syno" | grep $OID_DSMVersion | cut -d "=" -f2)
healthString="Synology $model (s/n:$serialNumber, $DSMVersion)"
DSMUpgradeAvailable=$(echo "$syno" | grep $OID_DSMUpgradeAvailable | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
case $DSMUpgradeAvailable in
"1") DSMUpgradeAvailable="Available"; if [ "$checkDSMUpdate" = "yes" ]; then healthWarningStatus=1; healthString="$healthString, DSM update available"; fi ;;
"2") DSMUpgradeAvailable="Unavailable";;
"3") DSMUpgradeAvailable="Connecting";;
"4") DSMUpgradeAvailable="Disconnected"; if [ "$checkDSMUpdate" = "yes" ]; then healthWarningStatus=1; healthString="$healthString, DSM Update Disconnected"; fi ;;
"5") DSMUpgradeAvailable="Others"; if [ "$checkDSMUpdate" = "yes" ]; then healthWarningStatus=1; healthString="$healthString, Check DSM Update"; fi ;;
esac
RAIDName=$(echo "$syno" | grep $OID_RAIDName | cut -d "=" -f2)
RAIDStatus=$(echo "$syno" | grep $OID_RAIDStatus | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
systemStatus=$(echo "$syno" | grep $OID_systemStatus | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
temperature=$(echo "$syno" | grep $OID_temperature | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
powerStatus=$(echo "$syno" | grep $OID_powerStatus | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
systemFanStatus=$(echo "$syno" | grep $OID_systemFanStatus | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
CPUFanStatus=$(echo "$syno" | grep $OID_CPUFanStatus | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
#Check system status
if [ "$systemStatus" = "1" ] ; then
systemStatus="Normal"
else
systemStatus="Failed"
healthCriticalStatus=1
healthString="$healthString, System status: $systemStatus "
fi
#Check system temperature
if [ "$temperature" -gt "$warningTemperature" ] ; then
if [ "$temperature" -gt "$criticalTemperature" ] ; then
temperature="$temperature (CRITICAL)"
healthString="$healthString, temperature: $temperature "
else
temperature="$temperature (WARNING)"
fi
else
temperature="$temperature (Normal)"
fi
#Check power status
if [ "$powerStatus" = "1" ] ; then
powerStatus="Normal"
else
powerStatus="Failed";
healthString="$healthString, Power status: $powerStatus "
fi
#Check system fan status
if [ "$systemFanStatus" = "1" ] ; then
systemFanStatus="Normal"
else
systemFanStatus="Failed";
healthString="$healthString, System fan status: $systemFanStatus "
fi
#Check CPU fan status
if [ "$CPUFanStatus" = "1" ] ; then
CPUFanStatus="Normal"
else
CPUFanStatus="Failed";
healthString="$healthString, CPU fan status: $CPUFanStatus "
fi
#Check all disk status
do
diskID[$i]=$(echo "$syno" | grep "$OID_diskID.$(($i-1)) " | cut -d "=" -f2)
diskModel[$i]=$(echo "$syno" | grep "$OID_diskModel.$(($i-1)) " | cut -d "=" -f2 )
diskStatus[$i]=$(echo "$syno" | grep "$OID_diskStatus.$(($i-1)) " | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
diskTemp[$i]=$(echo "$syno" | grep "$OID_diskTemp.$(($i-1)) " | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
case ${diskStatus[$i]} in
"1") diskStatus[$i]="Normal"; ;;
"2") diskStatus[$i]="Initialized"; ;;
"3") diskStatus[$i]="NotInitialized"; ;;
"4") diskStatus[$i]="SystemPartitionFailed"; healthCriticalStatus=1; healthString="$healthString, problem with ${diskID[$i]} (model:${diskModel[$i]}) status:${diskStatus[$i]} temperature:${diskTemp[$i]}";;
"5") diskStatus[$i]="Crashed"; healthCriticalStatus=1; healthString="$healthString, problem with ${diskID[$i]} (model:${diskModel[$i]}) status:${diskStatus[$i]} temperature:${diskTemp[$i]}";;
esac
if [ "${diskTemp[$i]}" -gt "$warningTemperature" ] ; then
if [ "${diskTemp[$i]}" -gt "$criticalTemperature" ] ; then
diskTemp[$i]="${diskTemp[$i]} (CRITICAL)"
healthString="$healthString, ${diskID[$i]} temperature: ${diskTemp[$i]}"
else
diskTemp[$i]="${diskTemp[$i]} (WARNING)"
fi
fi
done
syno_diskspace=`$SNMPWALK $SNMPArgs $hostname $OID_Storage 2> /dev/null`
#Check all RAID volume status
do
RAIDName[$i]=$(echo "$syno" | grep $OID_RAIDName.$(($i-1)) | cut -d "=" -f2)
RAIDStatus[$i]=$(echo "$syno" | grep $OID_RAIDStatus.$(($i-1)) | cut -d "=" -f2 | sed 's/^[ \t]*//;s/[ \t]*$//')
storageName[$i]=$(echo "${RAIDName[$i]}" | sed -e 's/[[:blank:]]//g' | sed -e 's/\"//g' | sed 's/.*/\L&/')
# modified by Tobias Schenke
# "timebackup" (when backup-job runs) and the "docker-feature" (since dsm 6.0, and if installed) mount volumes as a substructure of /"volume1/..." or "/.../volume1/..."
# in this case the former grep failed with more then one result.
# modified script to look for a line with '= "/volume1"' instead of 'volume1'
#storageID[$i]=$(echo "$syno_diskspace" | grep ${storageName[$i]} | cut -d "=" -f1 | rev | cut -d "." -f1 | rev)
storageID[$i]=$(echo "$syno_diskspace" | grep "= \"\?/${storageName[$i]}$\"\?" | cut -d "=" -f1 | rev | cut -d "." -f1 | rev)
if [ "${storageID[$i]}" != "" ] ; then
storageSize[$i]=$(echo "$syno_diskspace" | grep "$OID_StorageSize.${storageID[$i]}" | cut -d "=" -f2 )
storageSizeUsed[$i]=$(echo "$syno_diskspace" | grep "$OID_StorageSizeUsed.${storageID[$i]}" | cut -d "=" -f2 )
storageAllocationUnits[$i]=$(echo "$syno_diskspace" | grep "$OID_StorageAllocationUnits.${storageID[$i]}" | cut -d "=" -f2 )
storagePercentUsed[$i]=$((${storageSizeUsed[$i]} * 100 / ${storageSize[$i]}))
storagePercentUsedString[$i]="${storagePercentUsed[$i]}% used"
if [ "${storagePercentUsed[$i]}" -gt "$warningStorage" ] ; then
if [ "${storagePercentUsed[$i]}" -gt "$criticalStorage" ] ; then
storagePercentUsedString[$i]="${storagePercentUsedString[$i]} CRITICAL"
healthString="$healthString,${RAIDName[$i]}: ${storagePercentUsedString[$i]}"
else
storagePercentUsedString[$i]="${storagePercentUsedString[$i]} WARNING"
fi
fi
fi
case ${RAIDStatus[$i]} in
"1") RAIDStatus[$i]="Normal"; ;;
"2") RAIDStatus[$i]="Repairing"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"3") RAIDStatus[$i]="Migrating"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"4") RAIDStatus[$i]="Expanding"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"5") RAIDStatus[$i]="Deleting"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"6") RAIDStatus[$i]="Creating"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"7") RAIDStatus[$i]="RaidSyncing"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"8") RAIDStatus[$i]="RaidParityChecking"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"9") RAIDStatus[$i]="RaidAssembling"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"10") RAIDStatus[$i]="Canceling"; healthWarningStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"11") RAIDStatus[$i]="Degrade"; healthCriticalStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
"12") RAIDStatus[$i]="Crashed"; healthCriticalStatus=1; healthString="$healthString, RAID status (${RAIDName[$i]}): ${RAIDStatus[$i]} ";;
esac
done
if [ "$verbose" = "yes" ] ; then
echo "Synology model: $model" ;
echo "Synology s/n: $serialNumber" ;
echo "DSM Version: $DSMVersion" ;
echo "DSM update: $DSMUpgradeAvailable" ;
echo "System Status: $systemStatus" ;
echo "Temperature: $temperature" ;
echo "Power Status: $powerStatus" ;
echo "System Fan Status: $systemFanStatus" ;
echo "CPU Fan Status: $CPUFanStatus" ;
echo "Number of disks: $nbDisk" ;
do
echo " ${diskID[$i]} (model:${diskModel[$i]}) status:${diskStatus[$i]} temperature:${diskTemp[$i]}" ;
done
echo "Number of RAID volume: $nbRAID" ;
do
echo " ${RAIDName[$i]} status:${RAIDStatus[$i]} ${storagePercentUsedString[$i]}" ;
done
# Display UPS information
upsModel=$(echo "$syno" | grep $OID_UpsModel | cut -d "=" -f2)
upsSN=$(echo "$syno" | grep $OID_UpsSN | cut -d "=" -f2)
upsStatus=$(echo "$syno" | grep $OID_UpsStatus | cut -d "=" -f2)
upsLoad=$(echo "$syno" | grep $OID_UpsLoad | cut -d "=" -f2)
upsBatteryCharge=$(echo "$syno" | grep $OID_UpsBatteryCharge | cut -d "=" -f2)
upsBatteryChargeWarning=$(echo "$syno" | grep $OID_UpsBatteryChargeWarning | cut -d "=" -f2)
echo "UPS:"
echo " Model: $upsModel"
echo " s/n: $upsSN"
echo " Status: $upsStatus"
echo " Load: $upsLoad"
echo " Battery charge: $upsBatteryCharge"
echo " Battery charge warning:$upsBatteryChargeWarning"
fi
echo "";
fi
if [ "$healthCriticalStatus" = "1" ] ; then
echo "CRITICAL - $healthString"
exit 2
fi
if [ "$healthWarningStatus" = "1" ] ; then
echo "WARNING - $healthString"
exit 1
fi
if [ "$healthCriticalStatus" = "0" ] && [ "$healthWarningStatus" = "0" ] ; then
echo "OK - $healthString is in good health"
exit 0
fi
fiRe: Host check timed out check_snmp_synology
As a side note, we running the same plugin check_snmp_synology on the other NAS01 which is working without any issues.
The Synology NAS mentioned is located in another location, and my concern is that the server never gets to connect to the NAS.
I cannot run the command without getting the following error.
$USERNAME@$SERVERNAME:/usr/local/nagios/libexec$ ./check_snmp_synology -2 (mjgroup||public) -h $HOSTADRESS
Is (mjgroup||public) your community string? this likely needs to be quoted '(mjgroup||public)'
We definitely need to get it working form the CLI before moving forward.
The community i've set up is mjgroup.scottwilkerson wrote:Is (mjgroup||public) your community string? this likely needs to be quoted '(mjgroup||public)'
What is tried to illustrate was that i tried both mjgroup and public.
UPDATE:
I have configured the NAS boxes with SNMPv3 which seems to be working on one of the boxes when i'm running the plugin.
I can't access NAS02 from Nagios with the command.
Are you actually putting the synology IP in there or $HOSTADRESS proper? because the error looks like it is missing some of the info such as if you were entering $HOSTADRESS
I can run the following without any issues on NAS01scottwilkerson wrote:Are you actually putting the synology IP in there or $HOSTADRESS proper? because the error looks like it is missing some of the info such as if you were entering $HOSTADRESS
$USERNAME@$SERVERNAME:/usr/local/nagios/libexec$ ./check_snmp_synology -u USERNAME -p PASSWORD -h HOSTIP
I have already edited the resource.cfg file with the updated macros.
This is what i get in the web interface
NAS01 Server information OK 01-16-2019 15:42:54 0d 1h 37m 22s 1/3 OK - Synology "DS1515+" (s/n: "XXX", "DSM 6.2-23824") is in good health
From my point of view this means that it's configured correctly on NAS01 but i still get the following error on NAS02
NAS02 Server information CRITICAL 01-16-2019 15:41:21 2d 6h 30m 41s 3/3 (Service check timed out after 60.01 seconds)
Can you share the commands defined for each of these from the nagios service configuration?
Is this what you're asking for?
command_name check_snmp_synology
command_line $USER1$/check_snmp_synology -h $HOSTADDRESS$ -u $USER3$ -p $USER4$ $ARG1$
