EMC VNX StoragePool check
udaykumar
Post by udaykumar »
Hi Team,
We have EMC VNX Storage in our environment and we would like to add Storagepool check in nagios.
This check should give free space in each StoragePool configured on VNX Storage.
Please find Sample output of command we execute;
[nasadmin@xxxxxxx ~]$ /nas/sbin/naviseccli -h <SP IP> -user <username> -password <password> -scope 0 storagepool -list
Pool Name: Block_Pool_0
Pool ID: 0
Raid Type: Mixed
Percent Full Threshold: 70
Description:
Disk Type: Mixed
State: Ready
Status: OK(0x0)
Current Operation: None
Current Operation State: N/A
Current Operation Status: N/A
Current Operation Percent Completed: 0
Raw Capacity (Blocks): 216160647984
Raw Capacity (GBs): 103073.429
User Capacity (Blocks): 168045207552
User Capacity (GBs): 80130.199
Consumed Capacity (Blocks): 146078760960
Consumed Capacity (GBs): 69655.781
Available Capacity (Blocks): 21966446592
Available Capacity (GBs): 10474.418
Percent Full: 86.928
Total Subscribed Capacity (Blocks): 146078760960
Total Subscribed Capacity (GBs): 69655.781
Percent Subscribed: 86.928
Oversubscribed by (Blocks): 0
Oversubscribed by (GBs): 0.000
Disks:
Please help us with possible check to execute.
Re: EMC VNX StoragePool check
You would need to either create a plugin that calls that command and parses the data or try to find a plugin that does what you are looking for.
I think this plugin may be similar to what you are looking for
https://exchange.nagios.org/directory/P ... xe/details
Otherwise, here are the Nagios Plugin Development Guidelines
https://nagios-plugins.org/doc/guidelines.html
