Need offline document for Monitoring-VMware-With-Nagios-XI
robinagios
Post by robinagios »
I followed the below document to install Vmware dependency in RHEL 6.5 env
The below command fails to install since the environment doesnot have internet connectivity.
cpan -i UUID XML::LibXML Socket Socket6 IO::Socket::INET6 YAML
Do you have offline installation document? Is not what is the official place to download the above packages?
cdienger
Re: Need offline document for Monitoring-VMware-With-Nagios-
Post by cdienger »
An offline doc does not exist. https://metacpan.org/ will have the packages.
In addition to this, if you had "working" local repos, you could've installed some/all of the packages via yum:
yum install uuid-perl perl-XML-LibXML perl-Socket perl-Socket6 perl-IO-Socket-INET6
