I'm trying to setup a new environment and have started to put some hostgroups and checks in place, however I'm having no success receiving notification emails. I can see Notifications in the Event Log but do not receive them:
Host Notification 2019-01-16 15:12:28 HOST NOTIFICATION: <username redacted>;<hostname redacted>;DOWN;xi_service_notification_handler;CRITICAL - <IP redacted>: Host unreachable @ <ip redacted>. rta nan, lost 100%
My contacts.cfg:
define contact {
contact_name <redacted>
alias Unix Team
contactgroups Unix_CG
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period 24x7
service_notification_period 24x7
host_notification_options d,u,r,s,
service_notification_options w,u,c,r,
host_notification_commands xi_service_notification_handler
service_notification_commands xi_service_notification_handler
can_submit_commands 1
email <redacted>
address1 <redacted>
address2 <redacted>
use xi_contact_generic
Host config file:
define host {
host_name <hostname redacted>
use linux-server
alias <redacted>
address <redacted>
hostgroups linux-servers
check_command check-host-alive!!!!!!!!
contact_groups Unix_CG
register 1
Can someone point me in the right direction before I jump into the sea please?
Not Receiving Notifications
Re: Not Receiving Notifications
There are some Nagios XI user-level configurations that need to be set in addition to the contact object level stuff:
The most common "thing people miss" is the individual Nagios XI user preferences that are explained on Page 2 / Page 3 of the above documentation.
Seeing the notification dispatched to the desired contact is a good first step, and tells me you've probably got the contact object figured out. I'd double check the Nagios XI user settings.
There's also some generic troubleshooting steps here:
https://support.nagios.com/kb/article.php?id=36
More granular investigation should be performed by a support tech.
Have you checked the maillog for clues?...I can see Notifications in the Event Log but do not receive them...
# When using sendmail
tail -50 /var/log/maillogCode: Select all
tail -50 /usr/local/nagiosxi/tmp/phpmailer.logLog in (masquerade as) the user, click on the username in the upper right corner, review all of the Notification Options for accuracy, and send a "test" email.
