Core to XI migration - Notes missing from XI
stefanw
Post by stefanw »
Hi folks --
I am working on migrating our last (and largest) Nagios Core implementation into XI. We have almost 1800 Hosts and more than 7700 Services in this Core right now.
We make extensive use of notes_url and action_url and notes in Core, to provide info to everyone from support teams to business partners to C-level executives. That info in notes ranges from helpful to drop-dead must-have critical information. We have close to 6300 notes entries right now.
Some are in Templates, but most are specific to individual Host or Service objects.
The documentation I can find for the Core --> XI migration process does not address the notes data in a way that would make it visible in XI directly.
There have been previous support discussions such as https://support.nagios.com/forum/viewtopic.php?f=16&t=48226 where the suggestions involve either the Notes Component or the Action Component.
1. Is there a feature-enhancement on the XI roadmap which will get Notes as defined in CCM to show up in XI directly?
2. Is there a process that I can follow as part of the Core-to-XI migration process that will take notes data and populate the Notes Component?
3. Since we use the XI API extensively on our other implementations - and will be on this XI also - where can I find docs on getting the API to also populate / manipulate the Notes Component?
Thanks!
stefanw
Re: Core to XI migration - Notes missing from XI
Post by stefanw »
By the way, we can't enable CCM access for everyone, so it's not a solution to have people View in Nagios Core from the Advanced tab.
I would like to clarify something. Notes Component stores the data into the db. It has nothing to do with Nagios Core. You can however use the Actions component to view notes on hosts/services (defined directly or via a template). You can also install the "Nagios XI Custom Column Component", which will allow you to see host notes in a custom column, but not service notes. Here's a few examples:
define host {
    host_name                   Dummy
    notes                       TEST NOTE
    notes_url                   https://www.nagios.com/
    action_url                  https://support.nagios.com/kb/
    register                    1
In the GUI:
The two icons next to the hostname are links to the notes_url and action_url. My "test note" is all the way to the right.
Unfortunately, you are not going to be able to display service notes this way, unless you create your own "custom" component.
Having said that, you can define some actions in the Actions component (using the %notes%, %notesurl%, and %actionurl% macros) in order to view notes, notes_url, and action_url under the "Quick Actions". See an example below:
In the GUI:
In the REST API, you could add a host/service and add a note at the same time.
Example:
curl -XPOST "http://x.x.x.x/nagiosxi/api/v1/config/h ... x&pretty=1" -d "host_name=testapihost&address=127.0.0.1&check_command=check_ping\!3000,80%\!5000,100%&max_check_attempts=2&check_period=24x7&contacts=nagiosadmin&notification_interval=5&notification_period=24x7&notes=my test note&applyconfig=1"
"success": "Successfully added testapihost to the system. Config applied, Nagios Core was restarted."
Here's the config that was created:
define host {
    host_name                testapihost
    address                  127.0.0.1
    check_command            check_ping!3000,80%!5000,100%
    max_check_attempts       2
    check_period             24x7
    contacts                 nagiosadmin
    notification_interval    5
    notification_period      24x7
    notes                    my test note
    register                 1
Hope this helps.
One more thing - I spoke to our developers about adding notes directly in XI on the "Host Status Detail" and "Service Status Detail" page. I was told that this will be in the next major release of Nagios XI - just wanted to give you heads up. This would be much better solution than using the "Custom Column" component, which is quite old, not very efficient, and it may slow down very large systems.
