Google Map
andaks
Google Map
Post by andaks »
How to add new one?!
1. I have already installed google map with devices on it. But I need a new one to add another devices on it. How to do it?
2. And the second question is how to rename an existing one.
mguthrie
Re: Google Map
Post by mguthrie »
Can you clarify, a new one of what?
Currently the google maps component only allows for a single map to be defined, if you were looking for multiple user-defined maps. Otherwise, adding new hosts is documented below:
http://library.nagios.com/library/produ ... -nagios-xi
andaks
Re: Google Map
Post by andaks »
I need two google maps with different devices on it. For example one map with routers, another one with servers. Or it can be one map but with possibility of switching between the sets of devices.
mguthrie
Re: Google Map
Post by mguthrie »
I think having multiple saved maps is a really good idea for that component, as well as per-user maps. However, it may be a while before we have a feature like that implemented. NagVis might be a more flexible option to do what you need for something like this:
http://library.nagios.com/library/produ ... s-tutorial
andaks
Re: Google Map
Post by andaks »
already have the nagvis:)
mguthrie
Re: Google Map
Post by mguthrie »
Good deal, thanks for the feedback and feature ideas!
