Apply configuration takes more more to Apply
ITOMB_IMT
Post by ITOMB_IMT »
whenever i make a change monitoring/alerting in CCM, i apply configuration. it shows configuration applied successfully. when i again go to the monitoring/alerting in CCM, its saying "Changes detected! Apply Configuration for new changes to take effect." After applying configuration for 5-7 times i don't see any error. Any ideas on why its taking several attempts to apply configuration?
npolovenko
Re: Apply configuration takes more more to Apply
Post by npolovenko »
@ISSB_MAOST, Please run the following script to check&repair the database:
/usr/local/nagiosxi/scripts/repair_databases.sh
Is your database offloaded? Please run the following commands to check your php and system time on the XI server(It needs to match):
grep "date.timezone" /etc/php.ini
ls -l /etc/localtime
php -r 'echo date("D M j G:i:s T Y")."\n";'
date
echo "SELECT NOW();" | mysql -u root -pnagiosxi -h my-RDS-FQDN
php -r "echo date('r').PHP_EOL;"
strings /etc/localtime | tail -1
ITOMB_IMT
Post by ITOMB_IMT »
npolovenko wrote:@ISSB_MAOST, Please run the following script to check&repair the database:
date
Yes, our database is offloaded to a remote server.
#grep "date.timezone" /etc/php.ini
; http://php.net/date.timezone
date.timezone = America/New_York
# ls -l /etc/localtime
lrwxrwxrwx. 1 root root 38 Oct 15 10:15 /etc/localtime -> ../usr/share/zoneinfo/America/New_York
# php -r 'echo date("D M j G:i:s T Y")."\n";'
Thu Jan 17 10:06:37 EST 2019
# date
# echo "SELECT NOW();" | mysql -u root -pnagiosxi -h my-RDS-FQDN
NOW()
2019-01-17 10:07:24
# php -r "echo date('r').PHP_EOL;"
Thu, 17 Jan 2019 10:06:37 -0500
# strings /etc/localtime | tail -1
EST5EDT,M3.2.0,M11.1.0
when i ran repair databases script the nagios db shows ok whereas the nagiosxi and nagiosql throws "nagiosxi.xi_usermeta
note : The storage engine for the table doesn't support repair" and completes without any errors.
nagios offloaded database repair succeeded
nagiosql offloaded database repair succeeded
nagiosxi offloaded database repair succeeded
still the problem persists.
npolovenko
@ISSB_MAOST, Can you run the same time commands on the offloaded database server? Timezone and time on the DB server needs to match the time on the main XI. I've seen this issue a lot.
ITOMB_IMT
Post by ITOMB_IMT »
npolovenko wrote:@ISSB_MAOST, Can you run the same time commands on the offloaded database server? Timezone and time on the DB server needs to match the time on the main XI. I've seen this issue a lot.
Timezone and time on App and Db servers are the same
DB Server:
]# grep "date.timezone" /etc/php.ini
;date.timezone =
lrwxrwxrwx. 1 root root 38 Oct 4 07:54 /etc/localtime -> ../usr/share/zoneinfo/America/New_York
-bash: php: command not found
# date
Fri Jan 18 09:57:33 EST 2019
# echo "SELECT NOW();" | mysql -u root -proot
NOW()
2019-01-18 09:57:33
APP Server:
Fri Jan 18 9:57:04 EST 2019
# date
Fri Jan 18 09:57:04 EST 2019
# echo "SELECT NOW();" | mysql -u root -proot -h Remote server
NOW()
2019-01-18 09:57:51
Fri, 18 Jan 2019 09:57:04 -0500
ssax
Dreams In Code
Post by ssax »
Please go to Configure > Core Config Manager > Tools > Config File Management:
- Click the Delete Files button (don't worry, it's safe, they will be rewritten)
- Then click the Write Configs button
- Then try to apply configuration and let us know if the "Changes detected" issue is resolved.
Additionally, please post the output of this command:
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -uroot -pnagiosxi --table -h my-RDS-FQDN
Please PM me a copy of your profile as well so that I can look through your logs/configs, you can download it from Admin > System Profile > Download Profile.
Thank you
ITOMB_IMT
Post by ITOMB_IMT »
ssax wrote:Please go to Configure > Core Config Manager > Tools > Config File Management:
Thank you
| Table | Size in MB |
| nagios_acknowledgements | 0.00 |
| nagios_commands | 0.02 |
| nagios_commenthistory | 2.63 |
| nagios_comments | 0.02 |
| nagios_configfiles | 0.00 |
| nagios_configfilevariables | 0.01 |
| nagios_conninfo | 0.17 |
| nagios_contact_addresses | 0.00 |
| nagios_contact_notificationcommands | 0.02 |
| nagios_contactgroup_members | 0.00 |
| nagios_contactgroups | 0.00 |
| nagios_contactnotificationmethods | 0.35 |
| nagios_contactnotifications | 0.38 |
| nagios_contacts | 0.01 |
| nagios_contactstatus | 0.00 |
| nagios_customvariables | 0.04 |
| nagios_customvariablestatus | 0.04 |
| nagios_dbversion | 0.00 |
| nagios_downtimehistory | 0.05 |
| nagios_eventhandlers | 0.02 |
| nagios_externalcommands | 0.06 |
| nagios_flappinghistory | 0.01 |
| nagios_host_contactgroups | 0.00 |
| nagios_host_contacts | 0.00 |
| nagios_host_parenthosts | 0.00 |
| nagios_hostchecks | 0.00 |
| nagios_hostdependencies | 0.00 |
| nagios_hostescalation_contactgroups | 0.00 |
| nagios_hostescalation_contacts | 0.00 |
| nagios_hostescalations | 0.00 |
| nagios_hostgroup_members | 0.00 |
| nagios_hostgroups | 0.00 |
| nagios_hosts | 0.01 |
| nagios_hoststatus | 0.03 |
| nagios_instances | 0.00 |
| nagios_logentries | 11.59 |
| nagios_notifications | 0.80 |
| nagios_objects | 0.54 |
| nagios_processevents | 0.35 |
| nagios_programstatus | 0.00 |
| nagios_runtimevariables | 0.00 |
| nagios_scheduleddowntime | 0.01 |
| nagios_service_contactgroups | 0.01 |
| nagios_service_contacts | 0.01 |
| nagios_service_parentservices | 0.00 |
| nagios_servicechecks | 0.00 |
| nagios_servicedependencies | 0.00 |
| nagios_serviceescalation_contactgroups | 0.00 |
| nagios_serviceescalation_contacts | 0.00 |
| nagios_serviceescalations | 0.00 |
| nagios_servicegroup_members | 0.00 |
| nagios_servicegroups | 0.00 |
| nagios_services | 0.10 |
| nagios_servicestatus | 0.25 |
| nagios_statehistory | 0.46 |
| nagios_systemcommands | 0.04 |
| nagios_timedeventqueue | 0.00 |
| nagios_timedevents | 0.00 |
| nagios_timeperiod_timeranges | 0.01 |
| nagios_timeperiods | 0.00 |
| tbl_command | 0.06 |
| tbl_contact | 0.03 |
| tbl_contactgroup | 0.03 |
| tbl_contacttemplate | 0.03 |
| tbl_domain | 0.03 |
| tbl_host | 0.03 |
| tbl_hostdependency | 0.03 |
| tbl_hostescalation | 0.03 |
| tbl_hostextinfo | 0.03 |
| tbl_hostgroup | 0.03 |
| tbl_hosttemplate | 0.03 |
| tbl_info | 0.17 |
| tbl_lnkContactToCommandHost | 0.02 |
| tbl_lnkContactToCommandService | 0.02 |
| tbl_lnkContactToContactgroup | 0.02 |
| tbl_lnkContactToContacttemplate | 0.02 |
| tbl_lnkContactToVariabledefinition | 0.02 |
| tbl_lnkContactgroupToContact | 0.02 |
| tbl_lnkContactgroupToContactgroup | 0.02 |
| tbl_lnkContacttemplateToCommandHost | 0.02 |
| tbl_lnkContacttemplateToCommandService | 0.02 |
| tbl_lnkContacttemplateToContactgroup | 0.02 |
| tbl_lnkContacttemplateToContacttemplate | 0.02 |
| tbl_lnkContacttemplateToVariabledefinition | 0.02 |
| tbl_lnkHostToContact | 0.02 |
| tbl_lnkHostToContactgroup | 0.02 |
| tbl_lnkHostToHost | 0.02 |
| tbl_lnkHostToHostgroup | 0.02 |
| tbl_lnkHostToHosttemplate | 0.02 |
| tbl_lnkHostToVariabledefinition | 0.02 |
| tbl_lnkHostdependencyToHost_DH | 0.02 |
| tbl_lnkHostdependencyToHost_H | 0.02 |
| tbl_lnkHostdependencyToHostgroup_DH | 0.02 |
| tbl_lnkHostdependencyToHostgroup_H | 0.02 |
| tbl_lnkHostescalationToContact | 0.02 |
| tbl_lnkHostescalationToContactgroup | 0.02 |
| tbl_lnkHostescalationToHost | 0.02 |
| tbl_lnkHostescalationToHostgroup | 0.02 |
| tbl_lnkHostgroupToHost | 0.02 |
| tbl_lnkHostgroupToHostgroup | 0.02 |
| tbl_lnkHosttemplateToContact | 0.02 |
| tbl_lnkHosttemplateToContactgroup | 0.02 |
| tbl_lnkHosttemplateToHost | 0.02 |
| tbl_lnkHosttemplateToHostgroup | 0.02 |
| tbl_lnkHosttemplateToHosttemplate | 0.02 |
| tbl_lnkHosttemplateToVariabledefinition | 0.02 |
| tbl_lnkServiceToContact | 0.02 |
| tbl_lnkServiceToContactgroup | 0.02 |
| tbl_lnkServiceToHost | 0.02 |
| tbl_lnkServiceToHostgroup | 0.02 |
| tbl_lnkServiceToServicegroup | 0.02 |
| tbl_lnkServiceToServicetemplate | 0.02 |
| tbl_lnkServiceToVariabledefinition | 0.02 |
| tbl_lnkServicedependencyToHost_DH | 0.02 |
| tbl_lnkServicedependencyToHost_H | 0.02 |
| tbl_lnkServicedependencyToHostgroup_DH | 0.02 |
| tbl_lnkServicedependencyToHostgroup_H | 0.02 |
| tbl_lnkServicedependencyToService_DS | 0.02 |
| tbl_lnkServicedependencyToService_S | 0.02 |
| tbl_lnkServiceescalationToContact | 0.02 |
| tbl_lnkServiceescalationToContactgroup | 0.02 |
| tbl_lnkServiceescalationToHost | 0.02 |
| tbl_lnkServiceescalationToHostgroup | 0.02 |
| tbl_lnkServiceescalationToService | 0.02 |
| tbl_lnkServicegroupToService | 0.02 |
| tbl_lnkServicegroupToServicegroup | 0.02 |
| tbl_lnkServicetemplateToContact | 0.02 |
| tbl_lnkServicetemplateToContactgroup | 0.02 |
| tbl_lnkServicetemplateToHost | 0.02 |
| tbl_lnkServicetemplateToHostgroup | 0.02 |
| tbl_lnkServicetemplateToServicegroup | 0.02 |
| tbl_lnkServicetemplateToServicetemplate | 0.02 |
| tbl_lnkServicetemplateToVariabledefinition | 0.02 |
| tbl_lnkTimeperiodToTimeperiod | 0.02 |
| tbl_logbook | 0.02 |
| tbl_mainmenu | 0.02 |
| tbl_permission | 0.02 |
| tbl_permission_inactive | 0.02 |
| tbl_service | 0.11 |
| tbl_servicedependency | 0.03 |
| tbl_serviceescalation | 0.03 |
| tbl_serviceextinfo | 0.03 |
| tbl_servicegroup | 0.03 |
| tbl_servicetemplate | 0.03 |
| tbl_session | 0.02 |
| tbl_session_locks | 0.02 |
| tbl_settings | 0.03 |
| tbl_submenu | 0.02 |
| tbl_timedefinition | 0.02 |
| tbl_timeperiod | 0.03 |
| tbl_user | 0.03 |
| tbl_variabledefinition | 0.06 |
| xi_auditlog | 2.23 |
| xi_auth_tokens | 0.42 |
| xi_cmp_trapdata | 0.03 |
| xi_cmp_trapdata_log | 0.03 |
| xi_commands | 0.06 |
| xi_eventqueue | 0.03 |
| xi_events | 0.09 |
| xi_incidents | 0.02 |
| xi_meta | 1.52 |
| xi_options | 0.03 |
| xi_sessions | 0.03 |
| xi_sysstat | 0.03 |
| xi_usermeta | 0.19 |
| xi_users | 0.03 |
Please see the pm for "System Profile"
ssax
Dreams In Code
Post by ssax »
Please send me the output of this command on your offloaded db:
tail /var/log/messages /var/log/mariadb/mariadb.log /var/log/mysqld.log
Then run these commands on your XI server:
systemctl stop crond
systemctl stop npcd
systemctl stop nagios
systemctl stop ndo2db
pkill -9 -u nagios
for i in $(ipcs -q | grep nagios |awk '{print $2}'); do ipcrm -q $i; done
rm -rf /usr/local/nagiosxi/var/dbmaint.lock
rm -rf /usr/local/nagiosxi/var/event_handler.lock
rm -rf /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
systemctl start ndo2db
systemctl start nagios
systemctl start npcd
systemctl start crond
Then run this tail command (and leave it running):
tail -F /usr/local/nagiosxi/var/cmdsubsys.log
Then try to apply configuration through the web interface and once it completes/errors send me the full output from the tail command above.
ITOMB_IMT
Post by ITOMB_IMT »
Please see the results
On Database server:
]# tail /var/log/messages /var/log/mariadb/mariadb.log /var/log/mysqld.log
==> /var/log/messages <==
Jan 25 12:47:25 APP_Server auditmanager: Received wakeup signal before sleep finished
==> /var/log/mariadb/mariadb.log <==
InnoDB: http://dev.mysql.com/doc/refman/5.5/en/ ... oting.html
190125 10:15:48 InnoDB: Error: table `nagiosxi`.`xi_sysstat` does not exist in the InnoDB internal
InnoDB: data dictionary though MySQL is trying to drop it.
InnoDB: Have you copied the .frm file of the table to the
InnoDB: MySQL database directory from another database?
InnoDB: You can look for further help from
190125 10:20:34 [Note] 'CHANGE MASTER TO executed'. Previous state master_host='', master_port='3306', master_log_file='', master_log_pos='4'. New state master_host='Secondary_db_server', master_port='3306', master_log_file='mariadb-bin.000001', master_log_pos='46066554'.
190125 10:20:34 [Note] Slave SQL thread initialized, starting replication in log 'mariadb-bin.000001' at position 46066554, relay log './mariadb-relay-bin.000001' position: 4
190125 10:20:34 [Note] Slave I/O thread: connected to master '[email protected]:3306',replication started in log 'mariadb-bin.000001' at position 46066554
tail: cannot open '/var/log/mysqld.log' for reading: No such file or directory
On App Server:
PROCESSED 0 COMMANDS
.............PROCESSING COMMAND ID 4541...
PROCESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
No entry for terminal type "unknown";
using dumb terminal settings.
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.2
Last Modified: 2018-08-16
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Total Processes' on host 'Client_server' (config file '/usr/local/nagios/etc/services/client_server.cfg', starting on line 175)
Checking objects...
Checked 430 services.
Warning: Host 'client_server' has no default contacts or contactgroups defined!
Checked 21 hosts.
Checked 16 host groups.
Checked 0 service groups.
Checked 19 contacts.
Checked 4 contact groups.
Checked 127 commands.
Checked 23 time periods.
Checked 0 host escalations.
Checked 21 hosts
Checked 0 host dependencies
Checked 23 timeperiods
Checking misc settings...
Total Warnings: 1
Total Errors: 0
> Return Code: 0
OUTPUT=--------------------------------------
RETURNCODE=0
PROCESSING COMMAND ID 4543...
PROCESS COMMAND: CMD=1150, DATA=remove
CMDLINE=php /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncall
CMD: syncall
MSG: BPI configuration applied successfully! BPI configuration applied successfully!
OUTPUT=MSG: BPI configuration applied successfully! BPI configuration applied successfully!
RETURNCODE=0
PROCESSED 2 COMMANDS
cdienger
Post by cdienger »
Can you disable replication on the database temporarily as a test? I wonder if this may be preventing the database from being written to in a timely manner.
