Changing IP of Syslog Server
jjordan18
Post by jjordan18 »
Is changing the host IP on the Syslog Server as easy as changing it in the OS? Is there any other cleanup that needs to be done on the server to make such a change?
cdienger
Re: Changing IP of Syslog Server
Post by cdienger »
Correct, all it should take is changing the IP on the OS.
jjordan18
Post by jjordan18 »
Groovy. Thanks for the prompt response.
cdienger
Post by cdienger »
No problem :)
