check-host-alive IS defined
jbruyet
Post by jbruyet »
Hey all, my servers and upper-echelon workstations are being monitored just fine but they all show a status of Pending. I read that it's an issue with the check-host-alive command not being defined. As far as I can tell it IS being defined. Here's my stuff:
In host template:
name generic-host ; The name of this host template
notifications_enabled 1 ; Host notifications are enabled
event_handler_enabled 1 ; Host event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
process_perf_data 1 ; Process performance data
max_check_attempts 5 ; Pulled this value out of the manual
check_command check-host-alive-ping
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
notification_period 24x7 ; Send host notifications at any time
register 1 ; This host registered 3/8/12 to fight errors
In commands.cfg:
command_name check-host-alive
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
The error when I do nagios -v:
Error: # 'check-host-alive' command definition specified for host 'srv-Jobee' is not defined anywhere!
I'm struggling a little with this because my first Nagios server was on a Debian server and I kept having problems. On top of that files from a package install were in different locations than they are in a source install. SO, am I missing another file that needs the command defined in it?
Joe B
jsmurphy
Re: check-host-alive IS defined
Post by jsmurphy »
jbruyet wrote:check_command check-host-alive-ping
Spot the difference ;)
jbruyet
Post by jbruyet »
Sheesh! That's what I get for blindly following the instructions I get off of those web sites. Thanks AGAIN jsmurphy. You've rescued my bacon several times now.
I made the commands the same and now I just have a few Windows machines that are pending. I expect them to ALL be green before I go home this evening. Nope, I just checked and they're all green now.
Thanks again,
Joe B
jsmurphy
Post by jsmurphy »
A second set of eyes will sometimes notice something in seconds that you could otherwise spend days on :lol:
