Oracle DB Monitoring
jyoti22
Post by jyoti22 »
Hi Team,
We have a requirement to monitor oracle DB using Nagios. The current set up has OEM. Will Nagios be able to completely provide same monitoring as OEM?
I am aware we can install oracle plugins and monitor the orcale DB in Nagios, But will Nagios be able to replicate OEM features?
Regarding Reporting, can we use any other third party tools with NagiosXI to fulfill our reporting requirements?
Re: Oracle DB Monitoring
I am not sure what kind of metrics you can monitor with OEM. I am not familiar with it. However, you can review the check_oracle_health plugin's usage below to see what you can monitor via this plugin (used by the Oracle Tablespace wizard):
/usr/local/nagios/libexec/check_oracle_health -h
Copyright (c) 2008 Gerhard Lausser
  Check various parameters of Oracle databases
  Usage:
    check_oracle_health [-v] [-t <timeout>] --connect=<connect string>
        --username=<username> --password=<password> --mode=<mode>
        --tablespace=<tablespace>
    check_oracle_health [-h | --help]
    check_oracle_health [-V | --version]
  Options:
    --connect
       the connect string
    --username
       the oracle user
    --password
       the oracle user's password
    --warning
       the warning range
    --critical
       the critical range
    --mode
       the mode of the plugin. select one of the following keywords:
       tnsping                          (Check the reachability of the server)
       connection-time                  (Time to connect to the server)
       password-expiration              (Check the password expiry date for users)
       connected-users                  (Number of currently connected users)
       session-usage                    (Percentage of sessions used)
       process-usage                    (Percentage of processes used)
       rman-backup-problems             (Number of rman backup errors during the last 3 days)
       sga-data-buffer-hit-ratio        (Data Buffer Cache Hit Ratio)
       sga-library-cache-gethit-ratio   (Library Cache (Get) Hit Ratio)
       sga-library-cache-pinhit-ratio   (Library Cache (Pin) Hit Ratio)
       sga-library-cache-reloads        (Library Cache Reload (and Invalidation) Rate)
       sga-dictionary-cache-hit-ratio   (Dictionary Cache Hit Ratio)
       sga-latches-hit-ratio            (Latches Hit Ratio)
       sga-shared-pool-reload-ratio     (Shared Pool Reloads vs. Pins)
       sga-shared-pool-free             (Shared Pool Free Memory)
       pga-in-memory-sort-ratio         (PGA in-memory sort ratio)
       invalid-objects                  (Number of invalid objects in database)
       stale-statistics                 (Find objects with stale optimizer statistics)
       corrupted-blocks                 (Number of corrupted blocks in database)
       tablespace-usage                 (Used space in tablespaces)
       tablespace-free                  (Free space in tablespaces)
       container-tablespace-free        (Free space in tablespaces of container databases)
       tablespace-remaining-time        (Remaining time until a tablespace is full)
       tablespace-fragmentation         (Free space fragmentation index)
       tablespace-io-balance            (balanced io of all datafiles)
       tablespace-can-allocate-next     (Segments (of a tablespace) can allocate next extent)
       datafile-io-traffic              (io operations/per sec of a datafile)
       datafiles-existing               (Percentage of the maximum possible number of datafiles)
       datafiles-recovery               (Check if datafiles need media recovery)
       datafiles-offline                (Check if datafiles are offline)
       asm-diskgroup-usage              (Used space in diskgroups)
       asm-diskgroup-free               (Free space in diskgroups)
       soft-parse-ratio                 (Percentage of soft parses)
       switch-interval                  (Time between redo log file switches)
       retry-ratio                      (Redo buffer allocation retries)
       redo-io-traffic                  (Redo log io bytes per second)
       roll-header-contention           (Rollback segment header contention)
       roll-block-contention            (Rollback segment block contention)
       roll-hit-ratio                   (Rollback segment hit ratio (gets/waits))
       roll-wraps                       (Rollback segment wraps (per sec))
       roll-extends                     (Rollback segment extends (per sec))
       roll-avgactivesize               (Rollback segment average active size)
       seg-top10-logical-reads          (user objects among top 10 logical reads)
       seg-top10-physical-reads         (user objects among top 10 physical reads)
       seg-top10-buffer-busy-waits      (user objects among top 10 buffer busy waits)
       seg-top10-row-lock-waits         (user objects among top 10 row lock waits)
       event-waits                      (processes wait events)
       event-waiting                    (time spent by processes waiting for an event)
       enqueue-contention               (percentage of enqueue requests which must wait)
       enqueue-waiting                  (percentage of time spent waiting for the enqueue)
       latch-contention                 (percentage of latch get requests which must wait)
       latch-waiting                    (percentage of time a latch spends sleeping)
       sysstat                          (change of sysstat values over time)
       dataguard-lag                    (Dataguard standby lag)
       dataguard-mrp-status             (Dataguard standby MRP status)
       flash-recovery-area-usage        (Used space in flash recovery area)
       flash-recovery-area-free         (Free space in flash recovery area)
       failed-jobs                      (The jobs which did not exit successful in the last <n> minutes (use --lookback))
       sql                              (any sql command returning a single number)
       sql-runtime                      (the time an sql command needs to run)
       list-tablespaces                 (convenience function which lists all tablespaces)
       container-list-tablespaces       (convenience function which lists all tablespaces of all container databases)
       list-datafiles                   (convenience function which lists all datafiles)
       list-asm-diskgroups              (convenience function which lists all asm diskgroups)
       list-enqueues                    (convenience function which lists all enqueues)
       list-latches                     (convenience function which lists all latches)
       list-events                      (convenience function which lists all events)
       list-background-events           (convenience function which lists all background events)
       list-sysstats                    (convenience function which lists all statistics from v$sysstat)
    --name
       the name of the tablespace, datafile, wait event,
       latch, enqueue, or sql statement depending on the mode.
    --name2
       if name is a sql statement, this statement would appear in
       the output and the performance data. This can be ugly, so
       name2 can be used to appear instead.
    --regexp
       if this parameter is used, name will be interpreted as a
       regular expression.
    --units
       one of %, KB, MB, GB. This is used for a better output of mode=sql
       and for specifying thresholds for mode=tablespace-free
    --ident
       outputs instance and database names
    --commit
       turns on autocommit for the dbd::oracle module
    --noperfdata
       do not output performance data
  Tablespace-related modes check all tablespaces in one run by default.
  If only a single tablespace should be checked, use the --name parameter.
  The same applies to datafile-related modes.
  If an additional --regexp is added, --name's argument will be interpreted
  as a regular expression.
  The parameter --mitigation lets you classify the severity of an offline
  tablespace.
  tablespace-remaining-time will take historical data into account. The number
  of days in the past can be given with the --lookback parameter. (Default: 30)
  In mode sql you can url-encode the statement so you will not have to mess
  around with special characters in your Nagios service definitions.
  Instead of
  --name="select count(*) from v$session where status = 'ACTIVE'"
  you can say
  --name=select%20count%28%2A%29%20from%20v%24session%20where%20status%20%3D%20%27ACTIVE%27
  For your convenience you can call check_oracle_health with --mode encode
  and it will encode the standard input.
Send email to [email protected] if you have questions
regarding use of this software.
Please include version information with all correspondence (when possible,
use output from the --version option of the plugin itself).
It is probably possible as you have access to the data via the Nagios XI REST API. Having said that, integrating a 3rd party reporting tool to Nagios XI is not something that would be officially supported. We can try helping you out with it, but we cannot guarantee that this is going to work.
Let us know if you have any further questions. Thank you!
